problem
Old May 18, 2002 | 04:58 PM
Dan007's Avatar
problem
i have a liek where my y pipe meets the header and it produces this terrible sound when i accelerate ....if anyone has any ideas that would help me w/ this problem that would be great. Thanx!!
Old May 18, 2002 | 05:06 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Is the flange rusted off, or did the piece that holds it tight to the manifold (header as you called it) rust off?
You can buy a two piece connector (holds the Y-pipe to the manifold) at a garage for less than $10, let the car warm up, apply pentrating oil like mad to maifold studs, turn very slowly, if you think it is going to break off, stop!
Put the new connector aroung the flange on the Y-pipe.
Tighten it back up and it should solve the leak.
If your not to mechincally inclined, take it to an exhaust shop.
Old May 18, 2002 | 09:14 PM
KED85's Avatar
Take to a muffler shop.
IF you see white powder expect a cracked exhaust manifold.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
