Just Doing some planning for my Fall Project, What Am I missing Guys?
Old May 15, 2002 | 03:48 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
In the fall, I will buy a beater and finaly get to do some real work to my car, that way I won't be pressed for time and won't have to worry about haveing a car to ride to school/work. I am thinking about exactly what car, maybe a F-body, maybe not, but defiantly GM, but that doesn't matter now...
OK heres a list of what is going to be done performance wise:
(Let me know if I am missing anything including details)
Hopefully i'll have Exhuast (well catback), Intake & Ignition Done before then. See Reader's Rides for info on what I have done so far... (we'll just say this is a list of my future plans, majority will be done this fall)
----------------------------------- EXHUAST -----------------------------------
- Dynomax Catback (needs V8 Passenger Hanger)
- Hooker Quad Tips ( Hey, these add 5 HP, I swear )
- Camaro_hunter_d's Headers/Y- Pipe (anxiously waiting )
- Weld Entire System (For securety Reasons only)
------------------------------------ INTAKE ------------------------------------
- SLP Cold Air Intake (Requires Drilling for thermometer)
- Relocate Battery/Purge Cannister (Neccessary for CAI)
---------------------------------- IGNITION -----------------------------------
- MSD 6AL Ignition Box
- MSD 8.5 Super Conductor Wires
---------------------------------- COOLING -----------------------------------
- Finish installing Haydan Fan Switch
- Need new Fan shroud (Cracked when installing radiator, makes lotsa noise, so i unpluged fan, still under 160* )
- TB Coolant Bypass
---------------------------------- CHASSIS -----------------------------------
- Spohn Supframe (Bolt in, then Weld it too )
- BMR Strut Tower Brace ( TPI Version, requirs Shams)
- Global West Steering Box Brace or IROC Wonder Bar (Not sure Yet)
-------------------------------- SUSPENSION ----------------------------------
- Spohn Anti-Sway Bars
- Spohn Panhard Bar
- Spohn Lower Control Arms
- Edelbrock Shocks/Struts
- Eibach Lowing Springs
- Polyurathane Bushings for everything else
------------------------------- ENGINE/OTHER --------------------------------
- 3.4L Swap Boogie
- Cane 2030 Cam
- Crane 1.52 Roller Rockers and Lifters
- Forged Pistons ( can you gimme more info on this)
- IROC/TRANSAM Rear End, (Posi/3.73/Discs)
- Rebuild Tranny, TRansGo Shift Kit
- Underdrive Pullies
- Double Roller Chain ( What's This? )
What's an Air Silencer?
OK, you know the deal, gimmee feadback...
Old May 15, 2002 | 04:00 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
For Appearance...
---------------------------------- EXTERIOR -----------------------------------
- IROC Rims w/ Goodyear Eagle (ZR rated Tires)
- Stock 3 Peice Spoiler (Have 88 "Shorty" wing)
- IROC Hood w/ Louvers
- New Rear Windo Louvers (Old ones broke )
- All new Weatherstripping (GM for T-tops, aftermarket for everything else)
- Driving Lights ( Going to try the stock Switch, need to research this more)
- Polish Taillights/Turn Signal Housings w/ Plastic Polish (Turn signals require to take front off w/ Dremel)
- Xenon Blue Bulbs for Turn Signals/Sidemarker Lights
- Clear Sidemarkers
- 5% Tint on Bak, 35% on Side, 5% on front 5 inches (all VA allows)
- Sunset Metallic Orange Paint Job (Show Quaility, nothing cheap
- IROC lower Pinstripes
---------------------------------- INTERIOR -----------------------------------
- ACC Carpet, Front & Back (Defaint in Black)
- Custom ACC Floormats w/ "CAMARO" on them
- Black Leather 4th Gen Seats
- Black "DELUXE" Panels (Painted mine before i found this site, can you pokey dots)
- Repair Cracks in Dash (Not the pad, got a new one of those)
- Mount my Radio Pod (For 4th Gen Console Swap I did, see Pics Page for more info)
- Underdash panels
- Overhead Console
- Vinyl Wrapped Sunvisors/Sail Panels
- MacEwon WFG's w/ Wenon Blue Bulbs
- Black Dash Mat
- New Air Vents
- New Black Seat Belts (Anyone know what these cost from the dealer? )
----------------------------------- STEREO ------------------------------------
- Alpine or Pioneer Head Unit
- Infinity 60.5 Componetnte (Two Sets, one for my DJSExay kicks and the other for custom panels in the Sails)
- 600W 4 Chanel Amp (Not sure on brand)
- Two Rockford Fostagate Power HX2's 12" Subs
- Kenwood KAC-959 Amp (For Subs)
- Rockford Wires, Lightning Audio Capactitor (1 Farad, Digital)
Old May 15, 2002 | 05:02 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Hope you're one rich guy! Show us the finished project when finished! I really want to see it! I bet that's gonna be a lot of work. Good luck!
Old May 15, 2002 | 07:36 PM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
Well, if your gonna have a rebuilt engine/ forged pistons you may as well slap a 100 shot of N20 on there
Old May 15, 2002 | 08:30 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
You wont need the 6AL with an auto, save the $$ & just get the 6A. Not sure if they make a double roller timing chain, will have to investigate. Keep cannister, fuel/emissions reasons. Battery goes where spare used to go. Save up some more $$ for full rocker arms, use the money saved from the 6A & put towards these. New harmonic balancer. Have entire rotating assembly balanced. Forged pistons, look into the web sites given out here, & call P.A.W., they have decent prices. For the headers, when I lived in Arlington, they just did the tail pipe sniff, & did a visual for cat. Your area might be more laid back.
As a celebration of the car completion, take a nice leisurely 4 hr stroll to Ocean City, pop the T-tops off & cruise
Old May 15, 2002 | 08:38 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
OK I finished my Apearance list, I started it at work, and it was time to go...
As far as money goes, I go from paycheck to paycheck, and most of it goes into my car, and I don't have anything to do but plan between paychecks, so I just wanted to see yall's opinions... And see if I forgot anything. A shot of NOS would be nice but this car will be my Daily Driver (Is right now, and will be). After I am finished I want to do a L98 build up.
LONG LIVE THE 60* FOR THERE IS NONE LIKE IT!!!!!!!!!!!!!!!
I love the 60* and I want to keep one in there. I don't want an * in my Daily Driver. I am considering maybe in a year or so getting a 98+ Grand Prix GT with the Supercharged 3.8L 3800 V6 with the SLP GTX Ram Air Packagebut I don't know if I could get a loan that big when I'm only 18 years old. Maybe its only me wishing, but let me dream.
As far as getting something to drive while I work on my 60*, I want to go ahead and get the L98 powered Trans Am, but I would want to mad that too, and I cant afford insurance on two F-Bodies!!!!!!!!! So I'll probally have to get a old Cavalier, Grand Prix, Grand Am, Monte, etc thats under 500 dollars.
As far as funds, I'll be pulling two jobs all summer and not doing anthing with any of the money I am making from now on. Only Gas, and If I NEED to get parts then I will, otherwise, its all going into the savings account. I will defiantly be putting all of my graduation money into mods though, but that is given!!! Any more money I make, is SAVINGS for the Fall.
Also in the fall I'll start school at the local Community collage for Hospitality managment, and I'll have work study so I'm not too busy and I can have a job, so I can also work on my car too! I'll be busy, but that's how I like my life. Things won't change, I do all my work when it's dark outside (hey what's new?) but its all part of the game.
Anywhoo, gimme the details....
Old May 15, 2002 | 08:44 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
yeh i was wondering about the 6A, and whether I needed the REv Limiter anyways...
I want to RELOCATE the Purge, becuase I want the SLP Dual Cold Air intake, and It requires to relocate that purge cannister. I just replaced that d@mn thing a month ago, it cost me $115, af corse I am going to keep it!!!!!
Don't remind me of that d@mn emmisions check, I got to take it in July, and I think I am going to fail unless I can get my Cat to Y-Pipe connection to seal better, but I'll worry about that later...
BTW - What's a Sqap boogie? i heard of the swap boogie, but not a Sqap
Old May 15, 2002 | 08:47 PM
Engine: 5.7 / 7.4
I had a Datsun 200SX back in 89-92. BEst car I've ever owned. Vert dependable & good milage. THe bonnie is creeping up on it for being tops though.
Old May 15, 2002 | 09:56 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
hey man, just make sure you want to throw all that work into a V6
that seems like an awful lot
Old May 16, 2002 | 07:33 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I strive to be different
I love that car too much to get rid of it and buy an eight. So i fiure, if I gonna keep it, might as well mod the sh*t out it.
Old May 16, 2002 | 10:51 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'd love to have all fall to work on my car; I've gotta squeeze it all in the summer months....
For the extra $40, go for the 6AL. You can run the two step rpm module (or the three step) on it. I don't think you can attach a rev limiter to the 6A. Plus, what if the trans slips? I put the 6AL on my car.
Why forged pistons? You know they're $300 extra, right?
Welding the exhaust for security reasons- is exhaust theft big in your area? Weld the tips, maybe...
I don't see you needing the Spohn parts for the rear suspension at all... a V8, yes, but not our V6's. Lakewood (mrgasket.com) makes boxed LCA's for $100 and a track bar (panhard rod) for $100. You could box your stock pieces to save more money, too. I'm sure a welder would weld 'em up for $20. And with the money you save, go get a MIG welder (mine was $300 from Home Depot).
A double roller timing chain is stronger and lasts longer than a stock chain. The rollers reduce friction. The "double" means double chain, which reduces chain stretch, which keeps your timing more accurate over a long period of time. I bought mine (chain, cam sprocket, crank gear) from Summit, made by Cloyes, for $90.
There are Polish taillights for our car? Cool, I'm 1/2 Polish, who makes 'em?
The BMR STB fits our cars?
Don't look to an IROC for a 3.73/posi/disc rear gear, you need to find a Z28. The 3.73 stopped in '85. I grabbed my 3.73/posi/disc from an '84 trans am. If you go to an '82-83 axle, the brakes have standard-thread fittings, all 84-up has metric. Look for all my messages here (and on the suspension/chassis/brakes board) about my "3.73/posi/disc" axle.
Doesn't seem out of the realm for work done to a V6 car; I've done pretty much all the same to mine. (Exclusions being the exterior lights/colors/stripes/etc, some of the interior stuff like the wrapped panels, and the engine rebuild).
Ocean City.. that reminds me; I've gotta go try to grab a hotel at Virginia Beach for this year. (Went to OCMD last year, VB before that, OCMD before that- see the pattern?)
Old May 16, 2002 | 11:23 AM
KED85's Avatar
Find yourself a Classic Car and invest in that.
Your Fall project is so expensive.
Slip a 3.4 into your ride and just have some fun!
Spend the saved money elsewhere.
Old May 16, 2002 | 12:29 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
this is why i posted tom, i wanted feedback. Thanxs for the suggestion for rear suspension, i was debating about that... i love to find ways to save money.
This was mostly to get my ideas all in one list so i could see my fualts in my design.
Karl, Why would I want to restorea classic when I could have fun with a thirdgen. IMO, these are the greatest car ever (excluding the C3 Vette)???
I just want to have some fun and have fun working on this car.
OK, so is there anything else guys? Keep this stuff coming, i want to ssave some more money people...
Old May 16, 2002 | 01:52 PM
Car: 84 Trans Am
What kind of shape is your interior in? If its worn (and since you're doing appearence mods too) why not throw some new carpeting/4th gen seats in there? If you're doing nothing but making money to put into your car you may as well go all out
BTW, I may have a line up on a tranny for my car(only 40,000 miles on the rebuild) so she may be up and running again soon!!!! After that its time to start doing a lot of the things you are doing to yours :rockon:
Old May 16, 2002 | 02:54 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
i am doing that, didn't read my list? I getting those with graduation money can't wait, when I got the car, everything, and I mean everything in the interior was sun damaged.
Dash, pad, Steering wheel, seats, carpet, floor mats, console, ****er ****, headliner, dome light, panels, etc... All damaged by the sun. I will have a whole new BLACK interior w/ 4th Gen leather seats. Not sure if I want T/A or Camaro, whichever is the cheapest
Old May 16, 2002 | 03:10 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Tom,
There is a guy, with a name like Wasam or something like that, has a 3.1 Auto and He had a BMR Stut Tower Brace put over his 3.1. He had to get the TPI version with the center falttened out, but the rest is tubular. He had it professionally installed and they had to put "shams", not sure on thickness, between the Brace and the Mounts on the Strut Towers. I'll get the address for the purchase a little later, i have it bookmarked at home, im at work now.
that paw-lish not pool-lish
Boxed? Wound a tubular design be better becuase the boxed design would have stress on all four corners? Your the expert, you tell me
Old May 16, 2002 | 03:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Did I mention http://www.1aauto.com for the acc carpet? I bought it there for less than what acc's own site sells it for!
I never got the wonderbar installed on my car because of the curving radiator hose; I might hit the junkyards (or buy new!) a radiator for a v8 or 90-92 v6, which doesn't have the lower rad hose in the way.
Tubular is stronger than boxed, boxed is stronger than u-channel. But boxing is usually cheaper; especially if you're boxing your own.
Old May 16, 2002 | 06:53 PM
Engine: 5.7 / 7.4
Want to redo the interior cheap(inexpensive), yet good? when you're around dayton, come take a look at my interior. A wife who knows & teaches you how to sew, and Hobby Lobby can do a miraculess job on a worn & blah tan/brown interior.
Also, look for the ever illusive aluminum driveshaft. When going thru the junkyrds, bring a magnet to check for these.
Old May 16, 2002 | 07:12 PM
Car: 84 Trans Am
Hmm, guess I missed the 4th gen interior when I was reading your list. Hmm..........(I read your list, then compare it to the list in my mind of things I want to do to my bird)........oh yea what about a B&M megashifter?
Old May 16, 2002 | 08:01 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
i like the stock one with my Buick shifter ****. It gets the job done right. IMO the mega shifter is ugly, and if I ever got an aftermarket it would be the Hammer shifter.
TomP, yeh you mentioned that in the Body and Interior Forum, and agian, thanx, but I already know... Taht palce is great huh,cant wait to actually buy from there.
So is boxed all we need or would the extra money for tublar really benefit?
Old May 19, 2002 | 12:45 AM
AFrikinGoodTime's Avatar
Boxed lca's are stronger, especially at the links. Im not talking about box welding your originals, buy a good set of aftermarket arms. The only downside is more unsprung weight, but on a streetcar, who cares. Ive broken to many tubular products in my life. One of them Im lucky to still be here! People who manufacture tubular products should be required to magnaflux there welds!!!!!!!!!!!!! (To mention a name: Chisholm )
Jorlain
Aug 24, 2022 05:11 PM
Cleotiz
Jan 6, 2018 08:56 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 14, 2015 08:25 PM
