Non third gen question
Old Jun 4, 2002 | 12:26 AM
Camaro_1986_19's Avatar
Ok, My dad has a 1987 Ford Aerostar with a 3.0 V6, He could be sitting at a stoplight and the van will stall, But it starts right back up, What's wrong with this? He thinks fuel filter. This van is sweet but wouldn't give up my Camaro!!
Old Jun 4, 2002 | 01:43 AM
BitchinRS's Avatar
Check the timing. Also the idle air control may need cleaning. After that if he is still having a problem test the EGR valve. Basicly start with the cheapest and then work your way up.
Incorrect timing can cause a car to stall while idling, and a dirty IAC can do the same. A sticking EGR will cause the same symptom. Is the SES light on?
Old Jun 4, 2002 | 07:32 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Check for codes. the way is jakked but works, need a multi meter for it. First seen this style a few days ago @ AZ
Old Jun 4, 2002 | 12:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh yeah! I forgot about that! When I worked on that '88 Mustang I-4, the Haynes book went into this long description on how to check for codes with a meter. That really makes me glad that GM was smarter than Ford, all we need is a little piece of wire. I keep that wire in my center console, just in case!
Old Jun 4, 2002 | 07:12 PM
Ford Aerostar's are very good and reliable vehicles
Old Jun 4, 2002 | 07:20 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Thats why it stalls, eh??
Old Jun 4, 2002 | 11:40 PM
It's the first problem it's given my dad and he's had it for a little over 3 years
Old Jun 8, 2002 | 06:16 PM
KED85's Avatar
Vacuum leak!!!!
Check all hoses just like on the 60* V-6
Same story.
Sounds easy to fix!
Frozer!!!
Jan 19, 2024 04:55 PM
69 Six Pack
Oct 5, 2015 07:51 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
