Rattles when A/C is on
Old Jun 19, 2002 | 12:45 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Whenever my A/C is on, I think the tensioner is rattling, its really loud. Is my tensioner about to go? It doesn't rattle when the A/C is off. I also noticed that my car is VERY VERY VERY SLOW with the A/C on. Is it supposed to put so much load on the engine? Some cars you don't even feel the engine struggle.
Old Jun 19, 2002 | 08:55 AM
WaynesRS's Avatar
your tensioner is about to break . Mine did the same thing about 3 years ago . It gets VERY VERY VERY VERY slow , like you said , that is a symptom . Plus it will rattle and make noise .
Old Jun 19, 2002 | 09:47 AM
KED85's Avatar
Last time you did a tune up was????
With my 1985 S-10 Blazer (had the car since 1989 w/AC operational),
Yep, it does really drag down the engine power upon take off.
Up to and at speed, does well again.
Again, these are economy engines, designed to reduce emissions and get decent gas milage.
AND THESE ENGINES ARE OLD. Like over 100K miles and what, close to 20 years old now?
When was the last time ya met Jack LaLane at an Old Folks Home?
I can't wait to turn on the AC in my Blazer with the 3.4.
I can't wait to get my AC charged in the Firebird with a 3.4!
I believe a low milage 3.4 block will certainly overcome the drag of an operational AC unit, from a standing start.
I hope.
IF NOT, atleast I'll look cool as I loose the race for that open road space!
Old Jun 19, 2002 | 04:01 PM
I Cant Drive 55's Avatar
I agree the tensioner might be about to go. But it could be a couple of more things. The head pressure on the A/C compressor may be getting too high,putting more pressure on the belt. Some of the causes for that could be too much freon or filter /drier getting stopped up or radiator fan not coming on. If you know someone with guages have it tested. If not ,try the tensioner first because it would probably be cheaper than sending it to an A/C shop.
I have the same car as yours and my A/C puts some drag on the engine.
Old Jun 20, 2002 | 12:13 AM
89V6FBIRD's Avatar
Tenioner replaced. It was a bizznitch gettin the bolts out, had to move the alternator. Tell me somethin guys. Is the tensioner supposed to kinda bounce around very little at idle? It smooths out when the RPMs go up. This new tensioner has a more accurate indicator thats more sensitive. The rattling <i>did</i> go away.
Total cost $69.xx
$42 for the tensioner
$22 for a new belt.
Old Jun 20, 2002 | 12:46 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Originally posted by 89V6FBIRD
. Is the tensioner supposed to kinda bounce around very little at idle? .
Normal. Don't worry.
Old Jun 20, 2002 | 09:27 AM
WaynesRS's Avatar
Is it still very slow when you take off with the AC on ?
Old Jun 20, 2002 | 10:24 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
That is the exact problem i had a year ago, it was rattling like crazy under the extra load of the AC. I don't know if i noticed a change in my acceleration afterwards. Let us know the results.
Old Jun 20, 2002 | 04:34 PM
89V6FBIRD's Avatar
It doesn't drain it as much, and I noticed the air didn't get hot when I was stuck at a light, maybe because it was cooler today. But overall I'm satisfied.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
