Need alot of help!
Old Jun 22, 2002 | 02:40 PM
Krush 32's Avatar
Need alot of help!
OK heres the deal, I got a car for free( best kind eh!) cleaned it all up and its looks like it will make a good driver. except that when I try to start it, it won't start.it might semi-lug for about 3 sec. but thats it. So I tried to squirt some starting fulid into the plennum, it started and ran till the fluid burned out, so i'm assuming that the injecters are not poping off, How do i test this theory? PLEASE HELP!!!!!!!!
Thanks Krush
Old Jun 22, 2002 | 04:32 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
First step: Put a fuel pressure gauge on it and see if it's even getting fuel before worrying about injectors. If you don't have one, buy one. I got mine for about $30 at Sears.
With the key ON, engine OFF, the fuel pump should max. out at about 42-44 psi, then settle around 37-40 psi.
Old Jun 22, 2002 | 10:25 PM
KED85's Avatar
And that is the ONLY secure safe 100% way to know
exactly where you efforts will be lead.
No pump not a fun replacement nor inexpensive
BUT car is good ride & classic!
Old Jun 23, 2002 | 10:40 AM
RICHRAD's Avatar
What kind or make of car? Fill us in!
Fanatic1074
Oct 2, 2015 03:47 PM
customblackbird
Oct 1, 2015 04:30 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Marc Brown
Sep 28, 2015 01:40 PM
aharvel50
Sep 21, 2015 07:31 PM
