ticking inside my engine
Old Jun 25, 2002 | 01:42 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
i hear a ticking sound inside my engine
can someone please tell me what it is?
cuz i dunno what do to and i dont have a stethoscope to pinpoint it so im just trying to see if U guys might know anything or have and idea as to what it could be
i thank you very much for your help in the past
i hope U guys can help this thirdgener once more
thanks
Berlyn
Old Jun 25, 2002 | 02:35 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
ticking or clicking sounds can be caused by a lot. Does it get louder or faster when you rev the motor? The most common cause of a ticking sound is something in the valve train or an exhaust leak.
Old Jun 26, 2002 | 02:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm sure you have a stethescope lying around your garage... if not, you can buy one. It's just a length of heater hose. I think they charge $0.50 a foot? HOld one end next to your ear, and work the other one around the engine, making careful not to catch you, your clothing/jewelry, or the hose in the engine's fanbelts.
Old Jul 2, 2002 | 10:23 AM
Berlyn0963's Avatar
Car: 91 Camaro RS
sorry i havent replied in a while but its my cars time of the month agian and now i need U -Joint and rear axle bearings and seals
CRAP!!!!
anyways Yes it does get faster as i rev the engine
and lil louder too
Old Jul 2, 2002 | 11:08 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
I would try Tom's suggestion of a ghettoscope to try and see if it is coming from within the engine. Also feel around your manifolds while the motor is running for hot air coming from an exhaust leak...be careful not to touch anything hot, of course. Make sure all vacuum lines are secure and intact. Also check under the car at the AIR breather tube for the cat, they have been broken on a lot fo cars I've seen and create an exhaust leak.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 7, 2015 09:55 PM
