Nother quicke?
Old Jul 5, 2002 | 10:59 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Nother quicke?
How hard/ best way to change the thermostat?
Suggestions
Old Jul 6, 2002 | 12:20 AM
Camar_Hunter_c's Avatar
On mine I took the throttle body bolts out, and propped the thing on something(screwdriver) and that opened those damn bolts right up.
Old Jul 6, 2002 | 06:38 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
So is there a way I can do it without taking the plenum off?
Old Jul 6, 2002 | 09:30 AM
KED85's Avatar
YEP
13mm wrenches box & open
13mm fared line wrench
13mm deep & short socket
3/8" ratchet
extension various lengths
swivel joint
patience, cool shade
Pool for the back after ya bent over for couple hours.
OH
Get a Hawaiian Island Babe for a back rub after you take dip in the Pacific at Sunset!
IF you have those tools, you can get it off easiest.
Not fun, tho BUT can be done.
Watch out when ya replace.
Aluminum ya know.
LET THE SEALANT CURE A FEW MOMENTS (Go take break and have brew, it's downhill), before you join pieces.
Old Jul 6, 2002 | 05:21 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Kewl, thanks....
And I'm definatly down with the brew and babe.
Old Jul 6, 2002 | 09:05 PM
WaynesRS's Avatar
Thats how I changed mine (Karl's way) . I think its the best way . Becarefull on the fender to , those can be real nut busters !
Old Jul 6, 2002 | 10:03 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
muhahahahahahahahahahahaha
Old Jul 7, 2002 | 01:06 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
thanks for the info, Thats my next project after I get back from st. louis in a week. I got a pool, at a diff house , and a babe always around hell, its her car. And I found out about the nut busters putting my new cai on, ouch So basically, take the tb off, slide it out the way, and I can get to the stat easier??
Old Jul 7, 2002 | 11:45 AM
KED85's Avatar
With the combination of the tools listed above, you can accomplish this task without removal of the throttle body.
While you're at it, add a new radiator cap, too.
DOUBLE CHECK YOUR CONNECTION ON THE LOWER RAD HOSE ON THE RADIATOR!!
Losing mine/it fell off, cost me my 2.8 engine.
Oh well I got a 3.4 under my hood to make that problem go away!
MAKE SURE your lower hose has the coiled wire in it, so the hose doesn't collaspe under pressure.
Top rad hose, this detail does not matter, at all.
THIS IS NOT A HARD JOB, just lots of patience, tools for better grip and brews and babes for the job well done!
Hawaiian Sunset doesn't hurt either!
Aloha!
I keep thinking of the final Hawaii Five-O episode scene of the series.
Steve McGarrett overlooking Hawaii from top of construction building after the bad guy was "Book 'em Dan-O!"
Tracy Lord, the prono star stage name.
Came from Jack "Lord" of Hawaii fame.
Yes.
Know who the first name came from?
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
