Turn signal problems
Old Jul 17, 2002 | 10:21 PM
Tmtmtl666's Avatar
Ok, this is my dilemma. I have a 99 camaro v6 and the turn signals will light up but will not blink. However, the hazards work fine. All of my light bulbs have been checked and are functioning. I replaced the blinker flasher (round, silver canister) and the blinkers still don't blink. At this point i am thinking it is the turn signal switch in the steering column. Are there any other opinions on this before i go and tear out the steering wheel? Thanks for your time.
John
Old Jul 17, 2002 | 10:29 PM
WaynesRS's Avatar
I will give you one suggestion . If you tear out the stearing wheel , please becarefull that damn airbag does not pop the $hit out of you . Im assuming you will disconnect it huh ?
Old Jul 18, 2002 | 01:29 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
O.K.
Typical problem for old cars:
For a good turn signal's work (blink), the electric resistance or impedance must be the same for all the bulbs.
At first, you must be sure that all the turn signal bulbs are the same (use the original AC Delco or Sylvania, etc. replacement).
Second: Since the american cars have a relationship between turn signal and brake light systems, review this last system too.
Review batt voltage, terminals and connections for voltage "leaks".
Regards,
Denis V.
Old Jul 18, 2002 | 03:21 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I have a 99 camaro v6... did you mean 89, or could you not find a 4th gen board?
Both turn signals will not blink.
I know I had some problems with the wires breaking inside the case too the bulb. My 4 ways still worked but not my blinker I replaced the piece that holds the bulb (went to a bone yard and got one with 6 inches of wire) wired it back in. Done the cars signals worked again.
It does not matter if the bulb works. It could still be wiring. But if its in the colomn good luck.
Old Jul 21, 2002 | 07:34 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
theirs a fuse that makes it flash,try checkin that
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
