Torque Converter lockup switch?
Old Jul 25, 2002 | 11:53 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Ok, so our transmissions aren't computer controlled or anything at all, except with the signal to the torque converter to lock and unlock, which is just a simple on/off signal right? My grandpa, back in his prime, got sick of his torque converter in his Buick Skylark locking up at irritating times, and jumping between a locked and unlocked state, so he wired a switch to the inside of his car which bypassed the automatic lockup, so he could lock and unlock it at will. I thought this was a damn good idea to cheaply eliminate my little 40 mph torque converter kick problem. How hard would it be to do? And if any of you know, how much of a gas mileage drop would I see by leaving it unlocked most of the time around the city? The way I drive normally, I only get approx. 15 mpg city. I really dislike overdrive until my wallet starts getting thin.. Thanks guys.
-Brooks
Old Jul 26, 2002 | 03:21 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
keep it in drive then. However, comma, the torque convertor is most efficient when it is locked.
Old Jul 26, 2002 | 10:00 AM
Nixon1's Avatar
Wait....am I reading this right...you're saying the torque converter won't engage unless you're in Overdrive? Because as ar as I know, my torque converter lockup is at 40 mph. When I'm driving right around 40 mph, it locks and unlocks at the tiniest of speed/throttle changes..and when I'm slowing down through and past 40 mph, passing through 40, the converter rapidly locks and unlocks, kicks, and shudders. I used to think this was my transmission but I'm 90% sure it's the TC now. And yes, it does this in Drive too. That's why I want to be able to control it manually. And btw, I drive it in drive 75% of the time because I like to hear the engine, and I enjoy the added throttle response...but my mileage goes to hell so when I'm low on gas, I kick the overdrive on.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
gwade12
Aug 8, 2015 08:17 AM
