ANOTHER check engine light
Old Aug 10, 2002 | 01:49 PM
92RSMuscle's Avatar
well here is the deal
im drivin and then a check engine light comes on...i shut off the car and it goes off...turn it back on...and its still off, this would occasionally happen...any ideas on what it could be?
also, sometimes when im at a stop sign and i give it more throttle off the line than i should, i hear a THUMP and feel the car move...could this be lack of traction or transmission?
Old Aug 10, 2002 | 03:01 PM
Zirtbow's Avatar
Check your codes.. on the main page there is a faq that tells you how and a list of codes to see what your SES light is flashing..
Old Aug 10, 2002 | 03:43 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Re: ANOTHER check engine light
Check codes. Usually a Code 32 pops up. Know as the EGR and Vaccum problems.
As for the Thump, I would say you have a weak transmission mount. Buy a new one and install, problem should end.
Old Aug 11, 2002 | 12:00 AM
92RSMuscle's Avatar
thanks guys!
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
