Anyone see the 4.3L buildup in August's Hot Rod?
Old Aug 18, 2002 | 03:14 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Pretty cool. I was drooling with a stiffie the whole time I was reading the article...hee hee. Although I am a V-8 guy, I really like the 4.3 and would like to swap one in a thirdgen with a 305 someday. I know someone on here was trying to do that, but was having trouble with the exhaust (?). Just thought I'd point out the article, because I know that there is some interest in the 4.3 on this site. By the way, for good 4.3 info, try
www.s-series.org. I stumbled across it when I was looking for info for my wife's 92 blazer with the Vortec 4.3.
Old Aug 18, 2002 | 01:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
how about you scan that article and post it up here or on the web. i will put it on the web if you dont have a place.
Old Aug 18, 2002 | 09:26 PM
JRoy91RS's Avatar
Engine: 355
I would scan it in, but I'm embarrassed to say I don't have a scanner. I'm not sure if the issue is still on the shelf, but if you want some more specifics on the buildup (part numbers, etc.) I can give them to you.
Old Aug 21, 2002 | 03:15 PM
jimmbo's Avatar
hey i know its not an f body but
i just finished my s 10 4. 3 project and the motor made 307 hp 284 ft lbs torque on motor
haven't sprayed it yet but i will include dyno sheets after i do
Old Aug 21, 2002 | 03:27 PM
JRoy91RS's Avatar
Engine: 355
Man, that's awesome!!!!! Can you post a build sheet? What kind of induction are you using? I am really going to build up a 4.3 someday.
Old Aug 21, 2002 | 04:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: Anyone see the 4.3L buildup in August's Hot Rod?
Woah, too much information. I've gotta find that magazine. I remember taking it out of the mailbox and throwing it into my room. It might be gone forever
Old Aug 21, 2002 | 07:35 PM
JRoy91RS's Avatar
Engine: 355
Hee hee. I can't help it if I get excited . That Hot Rod was one of the best issues I've seen in a while. I was wondering what people are using as far as heads go for 4.3 buildups. Hot Rod used the crappy stock TBI heads. I know that the Vortec 4.3's are better, but I don't think anyone makes an intake for them (for a carbed application.) Jimmbo, how did you do it? I know the TBI heads are really holding that engine back. I know there are some aluminum circle track heads out there that GM made back in the late 80's early 90's, but good luck finding them, and when you do-- $$cha-ching$$$!!
Old Aug 22, 2002 | 12:29 PM
jimmbo's Avatar
hey fellas
its all stock heads and intake anyway
minor port work etc
the major thing was the camshaft and compression
raised compression a bit
and had a cam ground
i think its about the biggest camshaft that will work with the stock computer
other than that its just solid internals eagle rods with je pistons
only problem is
i didn't opt for the billet crank
so i guess i can be the dummy to find out much horsepower a stocker will take
everything else is just bolt on stuff
then just spray the **** out of it!!
jimbo
Old Aug 22, 2002 | 12:31 PM
jimmbo's Avatar
oh yeah
i know wilson manifolds
and duttweiller(Ken)
make manifolds for these things but trust me you dont even want to know tthe price
jimbo
Old Aug 22, 2002 | 06:03 PM
JRoy91RS's Avatar
Engine: 355
That's pretty cool. What are your cam specs? Are you running TBI or CPI? I think that Edelbrock and Weiand make carb intakes...so does Brodix.
Old Aug 22, 2002 | 06:06 PM
JRoy91RS's Avatar
Engine: 355
Oh yeah, I guess I should ask what year your S-10 is... that would clear up my head/intake questions.
Old Aug 30, 2002 | 04:53 PM
jimmbo's Avatar
its a ninety seven
with the x motor (vin code)
jimbo
taking it to the track on sat
gonna spray the **** out of it !
please dont break!
Old Sep 5, 2002 | 02:26 PM
jimmbo's Avatar
good news laddies
i got the truck to the track and was happy and not so happy
happy because the truck ran well on spray but ran a bit slower than i thought it would on horsepower
jimbo
Old Sep 5, 2002 | 02:47 PM
Ragnarok_Tyr's Avatar
Is the one you're referring to the 4.3L buildup using Vortech's new centrifugal setup for carbs? Got 575 hp out of it before it blew up. Even so, they figured you could get 500 reliable horsepower out of it. Any of you guys out there getting ideas?
Old Sep 6, 2002 | 03:52 PM
jimmbo's Avatar
nope this truck uses the stock fuel inj intake and computer!
jimbo
mrbird
Oct 20, 2015 03:43 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
ironbmt
Sep 27, 2015 06:00 AM
