It was the timing chain...Thanks Ked
Old Aug 18, 2002 | 10:16 AM
KJay's Avatar
Remember this thread?
https://www.thirdgen.org/techbb2/sho...hreadid=104136
My water pump went out on me and I took Ked's advice and put in a new timing chain and gears and the jerking and vibrating problem is now solved.
It runs a LOT better now. NO jerking anymore. Thanks Ked. Continue to harp on about the importance of a new timing set. At 130,00 miles it was just what the doctor ordered.
My timing was set at the stock 10 degrees.
But the engine does have a slight pinging in it but only when it is under extreme load, such as in lower RPM's while attempting to accellerate on an incline.
Wondering of the timing should be a little higher or if something else needs attention.
Anyway...Thanks KED...you were right on.
Jay
Old Aug 18, 2002 | 12:02 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I would check Vaccum lines first to see if there are any cracks in them.
If not:
Many people on this board, such as myself found that our cars ran better at 12-14* rather then 10*.
So if you have a timing gun go nuts and try it.
Old Aug 18, 2002 | 12:24 PM
I Cant Drive 55's Avatar
If your engine pings under a load at 10* DO NOT advance the timing any more it will make it worse. With a new timing chain 10* is just right. The pinging could just be the gas or maybe even plugs.
Old Aug 18, 2002 | 12:45 PM
KJay's Avatar
Wires (Accel), plugs, rotor, Cap, TPS, are all new.
I will attempt to check the vacume lines.
Looking in through the throttle body I can see a TON of black crud in there. I hate that fricken EGR...dumping crap in there.
I have a set of headers that have no provision for an EGR (Hookers) that I have not installed yet. Love to eliminate it if possible.
I would just be happy with it running stock if It would.
If it is gas, Do I need higher or lower octane?
Old Aug 18, 2002 | 06:04 PM
You shouldnt need it , but higher octane will help.
Also check plug gap.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
