A HOLE w/oil?
Old Aug 27, 2002 | 08:04 PM
HurtHorseZ28's Avatar
A HOLE w/oil?
I was looking down at my 2.8 V6 right next to the oil sending unit and there is this hole to the left of it and I can see oil in there! Um, is this supposed to be like this????? I wouldn't think so.
Old Aug 27, 2002 | 10:03 PM
WaynesRS's Avatar
a hole in the block ? Or where ? If its in the block it sounds like your freeze plug , is it leaking any oil ? Or maybe it just has a film of oil on it ?
Old Aug 27, 2002 | 10:12 PM
Nah, it's not a freeze plug. It is about a half inch circular hole to the left of the oil sending unit. I am not sure if it is film or not, I was just looking down there tonight and saw it. I haven't really had a chance to investigate it yet.
Old Aug 27, 2002 | 10:24 PM
WaynesRS's Avatar
Can you stick your finger in the hole ?
Is she moist ?
Old Aug 27, 2002 | 11:21 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Are you sure your not missing your dip stick or something??
Old Aug 28, 2002 | 02:05 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
are you sure you're looking @ the oilsending unit & not the fuel pump switch? I'm looking in the manual, & the lower of the two is for the fuel pump.
1. Check engine baay for oil
2. Check oil level
3. If oil good, have someone crank/start motor while you observe area (wear gogulators just in case)
4. check leaking oil.
Old Aug 28, 2002 | 03:42 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I have the hole too, no oil comes out of it. It's because before there would be a separate gage sender and a FP sender. GM combined it on the later years, but kept the same hole for the separate one. They plugged it w/ something. As long as it doesn't leak, you're fine. (The gauge sender might have to be replaced soon though)
Old Aug 28, 2002 | 03:48 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
86V6FBIRD you just reminded me of my HS days damn i miss them and that one day in paticular.
Old Aug 28, 2002 | 01:45 PM
89V6FBIRD's Avatar
Ahhh, I'm startin my senior year on Tuesday. I know a few cheerleaders, I remember you had swim team chix, personally, I favor our meaty latina cheerleaders. Gotta love that J.Lo booty...
Old Aug 28, 2002 | 04:09 PM
FAST RS's Avatar
What HS you go to i jsutr say you live in the valley
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
