More Problems
Old Aug 30, 2002 | 10:36 PM
87Bandit's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8lt V6
Transmission: TH700R4
More Problems
Again my car is running like crap. It keeps stuttering when i accelerate. For everyone that doesnt remeber me having these problems before, right before it started doing this, i replacecd the oxygen sensor and the fuel filter as part of rutine maintainence. Also my SES light has not came on at all. Does anyone know what this could be?
Old Aug 30, 2002 | 11:35 PM
86camarodriver's Avatar
This has been hapening to me also, a lot of people told me to take of the throttle body and clean out the IAC and to check the wiring whit a OHM meter, it may be that it has a bad wire or cloged up so it is starving for air, my main problem is at idle also.
I will have it cleaned ot tommorow and will let you know it it fixed it
David
Old Aug 31, 2002 | 02:47 PM
87Bandit's Avatar
Engine: 2.8lt V6
thanx, my car idles really good. Also I forgot to say that before it started happening, i had just installed a dynomax cat-back and a high flow dynomax cat, if that helps at all. Today, it was driving just fine, but watch it, ,tommorow the car will run like crap again
Old Aug 31, 2002 | 05:55 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Timing.
Could be a little out.
Old Aug 31, 2002 | 10:08 PM
Is your throttle position sensor in the right position? Mine was not and it helped quite a bit.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
