just 2 more questions
Old Sep 3, 2002 | 05:15 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
do i have timing chain or a belt on these 3.1 LHO's?
and are the trannys electronically controlled?
Old Sep 3, 2002 | 06:36 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Timing Chain, if you're going to replace, get the double roller one. To replace you have to remove the water pump, so get a new one.
700R4 is NOT electronically controlled. 4L60 is the 700R4, just a new name, 4L60-E IS electronically controlled (hence the E)
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
