highbeam issues
Old Sep 3, 2002 | 10:43 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
highbeam issues
ok,
My drivers side lowbeam light is a little (or lot) dimmer than my passenger side light. Then when i switch to the highbeams, the drivers lamp goes out, and the passenger lamp highbeam comes on. Does anyone know what would cause this, i'm guessing it's a wiring issue that came up. I changed the light out once, but the stupid thing did the same with the new on, and i'd kindalike to have two highbeams, and atleast two bright slowbeams. thanx in advance.
Old Sep 3, 2002 | 11:13 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
If you've already changed the bulb & it's still doing the same thing, check the voltage going to the lights. THere also might be a relay, but it would just provide power to both......
Old Sep 3, 2002 | 11:44 PM
KED85's Avatar
Were ya in an accident up front?
Ground wire issues here, I think.
Old Sep 3, 2002 | 11:48 PM
85f-bird's Avatar
Engine: 2.8L, LS1
damn....actually i was in a front end accident months ago, many months ago, and this happeend many months ago, just never posted for some reason.....hmmmm, where would i locate the ground, or would my haynes have it....gonna go wire hunting tomorrow. thanx.
Old Sep 4, 2002 | 12:09 AM
KED85's Avatar
Try to find an intact car in yard & check that front nose wire harness, also. See what you are missing or grab better wires, maybe.
Glad I gave ya the clue
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
