Drop in gas milage... Any Idea's
Old Sep 6, 2002 | 02:14 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Any ideas on what it could be.
My milage has seem to drop???
Old Sep 6, 2002 | 12:47 PM
pontiacguy1's Avatar
what car is it? I am guessing it is the one in your sig. Maybe you have a dead cylinder or the injectors are clogging and not spraying right. Could also have a clogging cat or something like that. What have you done to it, and what have you tried so far? Anything else that you noticed other than the drop in mileage? Stumbling, power loss, knocking, excessive brake wear etc...
Old Sep 6, 2002 | 01:05 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Are you throwing any new check engine lights? An Oxygen sensor on its way out will mess up your mileage...any sensors dealing with their air/fuel mixture ratio that go out will mess your mileage up...is it a real bad drop or just you seem to burn more lately? Do you have #'s or no?
Old Sep 6, 2002 | 03:11 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
hmm i got really low gas mileage on my car 2... i was looking through the console and i dont think its the injectors with how many recpeits i found where they were mentioned.. i got about 225 to the tank when i got the car.. i slight increase with the K&N... i drastic decrease in city with flows and a drastic increase on highway with flows 200city/300highway (WTF!) and i know the cats clogged i would enjoy the 300 in the city!
Old Sep 7, 2002 | 12:07 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I went from about 240 - 200
Maybe my O2 sensor is going out.
I'm pretty much catless.
It seemed to clear up a little after I put some injector cleaner in.
But no where near 240....
I'm confused???
Old Sep 7, 2002 | 01:39 AM
Nixon1's Avatar
When my O2 sensor started going, the car ran really rough..had a bad shimmy to it..and it ran like crap. Gas mileage sucked too..and I'd occasionally throw a code 13..lean exhaust at warm cruise from O2 sensor... Replacing the thing totally did the trick. Made a HUGE difference..just you've GOT to reset the computer after you do it. Doesn't seem like a big deal, but it is..my computer FREAKED at the new O2 sensor..ran like **** for days and threw a CONSTANT Manifold Air Temp sensor code for no reason until I killed power to it to let it completely reset.
Old Sep 7, 2002 | 07:15 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
How much is one of those bad boys....
Old Sep 7, 2002 | 10:33 PM
Nixon1's Avatar
$20 and change at Autozone for the Bosch OEM.
Old Sep 7, 2002 | 11:14 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
That's common. What usually happens is the O2 sensor becomes contaminated and constantly produces a voltage reading below 400mV because it can't "sense" any fuel. In turn, the ECM sees the low voltage and thinks the motor is running VERY lean so it DUMPS fuel into the motor causing the motor to run like total ***.
Was your O2 sensor black when you pulled it out?
Old Sep 7, 2002 | 11:17 PM
Nixon1's Avatar
It wasn't all black, but it had black on it in like a scorch pattern..out from the center. I figured I'd see a good improvement with the new sensor, although I wasn't expecting the computer to react the way it did.
Old Sep 8, 2002 | 04:53 PM
devianb's Avatar
I would look at the O2 Sensor and possible vacuum leaks.
Old Sep 8, 2002 | 07:27 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I'll check it out tonight...
Hopefully that is all it is....
Old Sep 9, 2002 | 10:39 PM
Nixon1's Avatar
If it's not the O2 sensor, well, at least it's one less thing you have to worry about later. And btw, once you take the original out, plan on throwing it away..don't look at it and if it looks new, put it back in, because chances are, you broke the thing taking it out. They're wicked sensitive, gotta be REALLY careful taking them out and putting them in. When I pulled mine out, I gave it to a friend who was running without an O2 sensor in his Trans Am to solve as a quick fix until he scrounged up some bucks for a new on....he got it in and had to remove it because it didn't work at all. And I was as gentle as I could be with it.
And hey KJ, in your user info section on the pic of your car...I see a distinct outline of headlight covers? Where'd you get them/who makes them? I bought some up at Autozone, the Auto Ventshade kind, just simple smoked ones, and they had MAJOR overlap on both sides, like 3/4 in...I returned them. Do yours fit right in the cutout??
crazynights
Aug 21, 2015 06:53 AM
wayshegoes
Aug 17, 2015 12:00 PM
BurlyChev
Aug 16, 2015 09:08 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
