water pump
Old Sep 10, 2002 | 05:25 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
water pump
how much does a new water pump cost ? and where should i go to get one? how much in labor? total?
thanks guys?
ooh yea and how much and where can i buy a double roller timing chain for my 3.1LHO?
Old Sep 10, 2002 | 06:39 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
55 canadian, which is 35 american, reconditioned. If you can remove a few bolts and put some silicon on the gasket you could remove it and install it in 30-35 minutes. Which would save you quite a bit on labor.
Old Sep 10, 2002 | 06:51 PM
1991rsblue's Avatar
i just did mine last week. i have a 91 3.1 engine. you have to take the air condition compressor off to take the steering pump off and then you have clear access to the pump. i got min eat autozone for 35.00 bucks with a lifetime warentee and so far my temps are 5-10 degree's lower. it took me about an afternoon to do it and it comes with a gasket.
Old Sep 10, 2002 | 08:40 PM
Joe_L's Avatar
Car: 1995 Z28
Forgot about A/C, I just had to remove the steering pump Bracket.
Probably looking at a couple hours.
Old Sep 11, 2002 | 09:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The biggest bitch is scraping the old gasket material off of the timing chain cover. The timing chain cover is aluminum, so it gouges easily with a scraper- gouge it too much and you can cause a leak with the gasket! I also use Permatex high-tack gasket sealant on the gasket... comes in a little silver can with a brush under the cap. Some bolts will need to have blue RTV smeared on them since they go through coolant passageways, otherwise, you'll get leaks through the bolts. The proper sealant is "PST", Pipe Sealant w/Teflon, but it's hard to find. Check out plumbing stores...
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
