Exhaust Questions??
Old Sep 11, 2002 | 01:30 AM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
Exhaust Questions??
i was just wondering what ppl were running for exhaust, mufflers, cat backs or otherwise, and where i could pick up a hi-flo cat?
BTW im running 80 series flows with 3 inch tips
shoppin for the hi-flo cat to complete the set
Old Sep 11, 2002 | 10:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Dynomax super turbo cat-back
Products For Power (supposedly Dynomax) high flow bolt-in cat
AP mandrel bent y-pipe
Megs round rolled edge tips, in chrome ( http://coneengineering.com/megs/megshome.htm )
Call Summit at 800-230-3030 for a high flow bolt in cat, the one I know of is the Catco, #CTO-4115 , look the price up at summitracing.com . It's where I got my PFP cat, but I don't think they sell those anymore.
Old Sep 11, 2002 | 09:05 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
In the sig, although I should probably bold it, since I love the flowmaster so much. My brother's running a flowmaster too, although I'm not sure what model. Also, one of the previous owners thought that it'd be a bright idea to weld everything together from the exhaust manifolds back. Makes it kinda hard to get to the bad fuel level sender in the tank seeing as how you have to drop the exhaust to get to it.
Old Sep 12, 2002 | 12:57 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I second that, Tom... I'll be running a the Dynomax Super-Turbo catback with a pipe through the cat (gotta love FL, no emissions regs!)....I can't wait to hear it. I'm ordering a set of Edelbrock exhaust tips too this afternoon..they look great. 2 1/2 in. welded up, with a 3 1/4 in. exit..chrome, intercooled. They're like $35...
Old Sep 12, 2002 | 02:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Joe, have you seen the 360 degree band clamps by Dynomax? You can butt two pipes together with them. You could always make a cut in your I-pipe in an "accessible area", I guess a few inches behind the cat, and then use the clamp to put the system back together. What's cool is when you drop the axle down to the ground, the cat-back exhaust just slides right out as one piece.
(That's my "tip" for installing a cat-back!! Much easier than trying to raise the car 30 feet in the air. In short, jack rear of car up, rest the rear frame rails on jackstands (in front of lower control arms, there's a pad on each side), and keep the jack under the axle. Remove lower shock nuts. Undo the clip holding the brake line to the chassis. Remove the track bar (panhard rod) and track bar brace. Lower the axle down, but watch the brake line and brake hose so you don't hang that 200 pound axle from them!! You don't want to fck the hose up! When the axle is down to the ground, pull the exhaust out.)
Here's a link to the clamps: http://store.summitracing.com/produc...earchType=ECat
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
