TPS and settings 2.8
Old Sep 17, 2002 | 07:06 PM
ron88bird's Avatar
HiYaAll,
I just purchased a new Throttle Position sensor. I believe at idle my settings should be 054 and around 4.25 at wot. What setting should I set my ohm meter at? Is it the black and blue wire to check cuz theres 3 wires.. help.. other than that..
Thanx
Ron
Old Sep 17, 2002 | 09:32 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Just put it on there, there isn't enough there to adjust. Besides the computer AUTO ZEROS the value if it reads UNDER 1.0
Old Sep 24, 2002 | 01:44 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Ryan, unlike our 3.1's, his '88 uses an adjustable TPS which needs to be set at around .44-.54 volts, then the ECM needs to be reset.
Old Sep 24, 2002 | 02:55 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Depends on what settings your meter has... use the lowest voltage setting possible for DC. Some meters are auto-ranging, so if you just have a "VDC" setting, use that. Otherwise you should go with a 5 VDC (meaning 0 to 5) or 10 VDC or similar.
Concentrate mostly on the idle voltage. I forget the specifics, and you could do a search for it, but the computer enters power enrichment (PE) mode at about 80% above idle voltage. So you don't need to hit 4.5 volts for WOT, as long as you're in the 4's, you're good. Glenn told me about this, so it should still be findable with a search.
Out of the three wires, you want the "B" and "C", which are the top two wires on the TPS. You've seen the tech article and know about making jumper wires, right?
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
