working on ram air and i have a ques?
Old Sep 22, 2002 | 02:43 PM
V6camaroman's Avatar
on my stock air set up i have a maf sensor. im taking that off. do i have to put it back on my new ram air or not? can someone answer this quick thanks.
Old Sep 22, 2002 | 05:19 PM
David Blalock's Avatar
I'm pretty sure it'd throw a code without it in there. I've got the 3.1 that luckily didn't get a MAF so I'm not positive though.
David
Old Sep 22, 2002 | 09:34 PM
WaynesRS's Avatar
LEAVE it on . YOU need that . or you will run extremely rich causing the gas to wash the oil off of your cylinder walls , which is a very bad thing .
Old Sep 23, 2002 | 06:41 AM
thanks guys i left it on. i just put the open element air filter where the stock round air cleaner box was. one more ques. on the stock air box the was a small wire connection hooked to it. what does that do? i disconected it because i took off the air box. it ran ok.
Old Sep 23, 2002 | 11:07 AM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
thats the air temperature sensor, just tape it to the side near the filtyer and it will be ok, thats whut i did.
Old Sep 23, 2002 | 01:00 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I did the same as Mike...doesn't cause any problems. Question though V6 : "thanks guys i left it on. i just put the open element air filter where the stock round air cleaner box was. one more ques. on the stock air box the was a small wire connection hooked to it. what does that do? i disconected it because i took off the air box. it ran ok."
Are you SURE you have an MAF? The setup you describe sounds like the 90's model setup, which is a cylindrical filter in a can, with the temp sensor screwed into the side, with the intake arm doing 2 90 degree bends into the throttle body. If this is your setup, you don't have an MAF sensor..this setup got rid of the MAF sensor in favor of an MAP, which measures airflow indirectly by using manifold pressure information (I think) and comparing it to a chart stored in comp memory... The can setup should only have 2 things in the way..the air temp sensor, which is not a problem, and the exhaust gas recirculation tube, which again is not a problem.
Old Sep 23, 2002 | 02:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
They used that MAT (manifold air temp) sensor on the MAF cars, too, same location, in the side of the air box, a two-wire connector.
Old Sep 23, 2002 | 03:17 PM
no i have the regular maf sensor. i still have the stock air box down until where the cylender shaped air box used to be. i took that off and put the open element where that was. i took it out and test drove it and in mid rpm if i let off the gas and hit it again it would hesitate like hell. i brought it back and taped the air temprature sensor to the side of the open element. took it out again and had no probs. its working great now.
Old Sep 23, 2002 | 08:01 PM
Nixon1's Avatar
Tom, my comment wasn't whether he had the MAT or not..I know that...but I wasn't aware they used an MAF sensor for one of the years that they made the can and arm intake system. I thought the dual snorkel exclusively got the MAF, while the can exclusively got the MAP.
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
