Cam and rockers q's
Old Sep 23, 2002 | 08:18 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Cam and rockers q's
I'll try to keep this brief.. I've already done a post about this kinda thing and most of you said you liked the Crane 2030 hydraulic cam...would you be able to tell me exactly what to look for on Summit, or better yet the parts #? I'm looking for a kit so I get the lifters too.. Sorry but ya know, I don't know JACK about cams so I dont even know where to begin to look. Also, I've heard about half the people here say to get 1.52 roller rockers, and the other say 1.6. Which set would be the best for the 2030 cam...this is assuming the rockers are only for this engine, I'm not doing a 3.4 swap or anything. Thanks guys.
Old Sep 23, 2002 | 08:40 PM
AFrikanGoodTime's Avatar
Re: Cam and rockers q's
With either rockers you'll have to change the springs using that cam. You might as well go with the 1.6 to get the extra lift if its power that you seek.
Old Sep 23, 2002 | 08:43 PM
Nixon1's Avatar
Ok..yes, it's definitely power I'm looking for. I want a BEEFY cam.
Old Sep 24, 2002 | 05:29 PM
Nixon1's Avatar
Will the 1.6 rockers make clearance or would I need to buy higher valve covers? (Not that I probably wouldn't anyways, the stock ones are UGLY)
Old Sep 24, 2002 | 10:08 PM
You'll need the fiero covers.
Old Sep 25, 2002 | 05:58 AM
Nixon1's Avatar
Fiero covers... As long as they don't say 'Fiero', that works for me!
Old Sep 25, 2002 | 06:58 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
nope don't say fiero, hook up to the link in my "profile" below and you can see a set of them in a 3.1l
Old Sep 25, 2002 | 10:54 AM
Dale's Avatar
Engine: 350 S-TPI
oo, BTW, if you cant get the bolts for the valve covers, go to autozone, get the metric bolts that are 6-1.00x25MM (?) with washer built on it, then get some washers that are a little bigger then the wasers built onto them, and then grind like the last 1/16-1/8" of the bolt of at home, and WALA, should have it licked.
Old Sep 25, 2002 | 02:39 PM
Nixon1's Avatar
Those look pretty nice.. I like your engine bay..nice detailing. The plenum looks AWESOME. Aluminum/chrome hi-temp spraypaint?
Old Sep 25, 2002 | 02:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't have a part # handy, but you can go to the compcams.com website, get a part #, and look it up at summitracing.com . Or you can call Summit and ask them for a part # and price check. You should replace valvesprings anyway because the ones you have are old! As to 1.52 vs 1.60, remember these affect the "gross lift" of the cam. You can check the gross lift by reading the cam specs, and multiplying the cam lift times the rocker arm ratio. In cam specs, gross lift is usually calculated using a rocker arm ratio of 1.50. For example, on a cam with an intake lift of .282", using a rocker arm ratio of 1.50, you get gross lift of .423. For 1.52, you get 1.52 times .282 which = .428. 1.60 rockers yield a .451 gross lift.
Thanks for the tip on the bolts, Dale!
Old Sep 25, 2002 | 03:09 PM
Nixon1's Avatar
The more lift, the better, right? Because I know little about cams in terms of numbers...so all the figures and mathematics might as well be in arabic to me!
Old Sep 26, 2002 | 02:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It should be; as long as the intake and exhaust can keep up with it. I've even heard of some guys mixing different ratio rocker arms in, like, using a 1.52 for intake, and 1.60 for exhaust.
Old Sep 26, 2002 | 03:38 PM
Dale's Avatar
Engine: 350 S-TPI
Nope, its the dupli-color color change you can get at autozone, pep-boys, some wal-marts, I just put it on heavy, and clear coated over it.
Old Sep 26, 2002 | 03:40 PM
Dale's Avatar
Engine: 350 S-TPI
Tip on the bolts were for metric cars, I'm not sure when they swaped from american to metric.
Old Sep 26, 2002 | 06:46 PM
Nixon1's Avatar
Have you heard of any success with mixed ratios? I figure they sell them in a minimum of 12 probably anyways...so I'd have to buy 2 complete sets, it'd be too much money...but still, it's a thought
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Stryker412
Sep 7, 2015 09:11 AM
