engine swap?
Old Oct 2, 2002 | 04:36 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
engine swap?
Hello , i have a 2.8 multi port fi v6 in my car right now and i wanted to change out the motor eventually to a bigger six or an eight will the computer accept any changes in the engine block like that? Thanks
Old Oct 2, 2002 | 05:05 PM
Brian K's Avatar
3.4 will be your best bet.. Actuall it is the only one that will work with your tranny.. Do that swap, enjoy and save for a v8 build up...
Old Oct 2, 2002 | 05:10 PM
The computer will accept that without modifications?
Old Oct 2, 2002 | 05:54 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
From what I heard
From what I heard, the computer would accept this because:
1)you will just be using the 3.4L Block.
2)you will be re-useing the 2.8L FI, etc.
3) It's still a Sixty Degree V-6.
I am going to try to get ahold of a 3.4 Also.
I want to put on in this winter, along with 4.10 gears. ( I only city drive, Highway every now and then)
IF I get a vehicle to drive in the winter I want to find 4th gen seats, Center Console, and New Carpet. I want to swap My idiot lights for real gauges.
Then after all of that I want to find some rims.
I want to take some pics of my car&swap; to bad I dont know anyone with a digital Camera.
Old Oct 2, 2002 | 09:35 PM
Very cool which year came with the 3.4? 93-97...? I will be doing that conversion, but all the 2.8 stuff will fit (most) I plan on getting headers new cam (rough idle) an edelbrock throttle body and heads but everything else should line up right?
Old Oct 2, 2002 | 10:05 PM
KED85's Avatar
Read my Tech thread about the swap
I wrote it
I've done it & I'm doing it in my Blazer, too.
I only do street legal smog swap for CA approval. If ya wanna mod beyond what factory did, that's up to you.
Install, get running, then modify.
My suggestion.
How's your tranny?
Ya gonna need a rebuild if ya haven't done so.
WHY? So much torque & power.
EVERYONE of swappers report loose of tranny (one clutch!), so much power!
HP 165
Torque 200 foot pounds
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
