4th gen rear in a 3rd?
Old Oct 12, 2002 | 08:57 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Ok, I've got a 3.42 open now behind the 6. I just got a set of Salad Shooter 4th gen rims (without knowing about the damn b/s difference - remind me to smack GM for changing it) and figured hey - the 3rd gen rears are weak. I'll just switch to a 4th gen rear! What different 4th gen rears were available, behind the 3.4? Anyone know? I'd like a 3.42 Posi setup...
Old Oct 12, 2002 | 10:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
save your money on the rear. you have better gears than most of them. get a posi unit, or powertrax unit.
only way your gonna break the rear is if you put a realy built motor in in, & you're tranny will most likely break first.
Old Oct 13, 2002 | 11:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Can't you use spacers to make the rims fit? I could've Sworn I heard something about that. Maybe do a search on the suspension/chassis/brakes forum?
(Loving my new wireless internet via my laptop, had to try it out tonight, damn this thing is FAST! )
Old Oct 14, 2002 | 01:05 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
My friend put a rear end form a 96 trans am on his 90 camaro and didnt have any problems that i know if except the fact the guy who sold it to him knew it had a broken tooth and 2 weeks later the rear end went along wiht his trnany.
Old Oct 14, 2002 | 05:29 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i got my 94 Z28 rearend for $200
it was extremely easy to put in
the 3rd gen and 4th gen rear are the exactly the same except for the 4th gen rear being a tad bit lighter
the 4th gen rears are not nessacerily stronger though
i bought mine because:
i wanted rear disc brakes
i wanted posi
my Z28 had a 2.73 rear and i wanted something better than that
(the 4th gen rear i put in has 3.23's)
plus when i pulled the old rear out, i discovered the posi was shot anyway
hope i helped
Old Oct 14, 2002 | 08:30 PM
Xenodrgn's Avatar
4th gen rears are also wider... no?
Old Oct 14, 2002 | 08:39 PM
Doward's Avatar
correct, about 2".
4th gen rear, combined with 2" spacers in the front - use 4th gen wheels.
Old Oct 16, 2002 | 03:06 PM
LT1guy's Avatar
Car: 1987 Trans Am
If you want a 3.42 posi with discs, you'll need the rear from any 94-02 6 speed Z28 or TA. The 93s had 3.23 gears.
Old Oct 17, 2002 | 09:53 AM
90RS3.1's Avatar
Do the stock third gen wheels fit on the 4th gen rear or does that make a difference at all
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
