My Bad!!! crap
Old Nov 7, 2002 | 07:58 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
My Bad!!! crap
had the battery charged, put it back to see if lights liked a charged batt, and turned the key a little too far. engine rotated, but then I rememberd " Hey, you aint put the oil filter on or put oil in it yet, or even tranny fluid ". stopped cranking. at least I don't need to add spacersto the stater. also haven't put the radiator back in , am leaving it out for more room to put in headers. Also haven't hooked up plug wires. found out I set the motor up @ cylinder#2 tdc stupid f*rd engine numbers. now I get to find #1 tdc. also, the dash gauges aren't coming on or lighting up. is/are there just fuses for this, or is it powered from the wire coming off the alt?
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
bamaboy0323
Sep 12, 2015 07:14 PM
