I'm thinking... scary stuff here
Old Nov 18, 2002 | 11:57 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I've got a 2.73 out of a '92 RS.
I've got a 3.42 in the '88 now.
Now, here's the scary stuff -
IIRC, the '92 (305 v8) has 28 spline axles.
My '88 has 26 spline.
I thought that there was an SLP Posi out there for like $99?
The plan -
'88 Gears (3.42s) with the 28 spline '92 axles + $99 posi unit == 3.42 Posi for $99?
Am I thinking clearly, or clearly delusional?
Old Nov 18, 2002 | 12:12 PM
big_al_47's Avatar
Good plan, but the 2.73 gears are on a different series carrier than the 3.42's, and the two carriers require different gears. You could use an Eaton or other posi unit with the 3.42's and the 28 spline axles, just make sure the posi you buy is for the 3.42's and not the 2.73's.
Old Nov 18, 2002 | 12:16 PM
KED85's Avatar
"I thought I was gonna be President"
Al Gore
Spools cost that little. No to spools on the street.
The lower numbered gear carrier is different sized than the larger numbered gear carrrier.
Old Nov 18, 2002 | 12:51 PM
Doward's Avatar
Yeah, I had figured to use the current 3.42 gear carrier, with a posi unit, and the 28spline axles... would that work?
Old Nov 18, 2002 | 12:57 PM
big_al_47's Avatar
The posi is an integral part of the gear carrier, when you replace an open differential with a limited slip of any kind, the entire carrier is replaced, not just the spider gears. That's why it is important to order the correct unit for the gears you intend to use. All you will use out of your current 3.42 rearend is the gearset and axles, everything else should come with the new posi, bearings, seals, shims, etc.
Old Nov 18, 2002 | 01:40 PM
Doward's Avatar
Ah.. ok, I see
Old Nov 18, 2002 | 02:02 PM
ctandc's Avatar
YOU ARE RIGHT....
Pull the 28 spline axles from the 2.73 rear.
buy the $99 take off Torsen posi unit from www.slponline.com
Put both in the '88 3.42 rear and be happy.
HTH
Old Nov 18, 2002 | 02:21 PM
Doward's Avatar
wtf... so I can use my 3.42 gears/carrier ('88) with the '92 28 spline axles, and that POSI, and wham - 3.42 POSI?
Old Nov 18, 2002 | 05:36 PM
KED85's Avatar
OK, I'll bite & be educated.....
What he said!
Old Nov 18, 2002 | 10:40 PM
ctandc's Avatar
It's really as simple as it sounds, although you'll want to pay someone who knows what they're doing to install it.
SLP sells take off posi units from 4th gen's for $99. It's made for 28-spline axles, and it ONLY fits 3.23 gears and LOWER ( HIGHER NUMBER, so the 3.42's are fine ).
Take the posi, and your axles to someone to set it up. Shouldn't run more than $150 or so to install.
To a SEARCH for "zexel" or "slp posi" and start reading. Pretty popular swap for the low $$$ investment.
HTH
Old Nov 18, 2002 | 11:05 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thinking and Drinking but, the ring & pinion according to what Ive read in JUG's exc Jegs says somthing like 3.08 gears only fit 3.08 and lower carriers; 2.73 and vice versa 3.23 and up.
Old Nov 19, 2002 | 11:51 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
no you arent smokin crack get the zexel-torsen differential from slp or a few other places that sell them for around 100 bucks. mount your 3.42 gears on it, it is a 3-series carrier, fit it with the 28 spline axles into your rear housing, get it properly shimmed and spaced and away you go
Old Nov 19, 2002 | 12:24 PM
KED85's Avatar
You're telling me that I can pick up from SLP their new vehicle take off units selling for one hundred & slip them into my current 1985 ride rear axle?
And also slip it into my S-10 Blazer ride 1989 rear axle?
Old Nov 19, 2002 | 12:29 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
if you switch to 28 spline axles, yes you can. The Zexel is a 3-series carrier for GM 7.5/7.62" 10 bolts. But you need the 28 splines from 89? or later fbodies, maybe trucks got them a little earlier, not sure though. go to www.torsen.com for how the zexel is different from other limited slips
Old Nov 19, 2002 | 06:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, '89 was the changeover year. More than likely, an f-body from '89 will have 26 spline axles. Only way to know for sure is to remove the rear cover, undo the pinion lock bolt, and pull an axle out to count splines. (Beware, those little f'ing lock bolts like to snap, and then you're pretty well screwed, because the axle housing blocks your straight-line-access to the lock bolt- a drill won't fit)
But if you don't have the tools (dial indicator, torque wrench) or parts (bearings, pinion seal, shims, gear chalk), you should probably pay a professional to do the job. Swapping gears isn't a take-out/bolt-in job, there's a few settings that have to be taken care of (backlash, preload, etc), and if they're not set correctly, you can ruin the gears instantly.
Old Nov 20, 2002 | 08:41 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Good to here Tom is Back!!!! I thought you left
Old Nov 20, 2002 | 10:12 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL, no, just for a while.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
anesthes
Sep 30, 2015 07:48 AM
