Need help on timing
Old Nov 27, 2002 | 12:07 PM
typevoid's Avatar
Need help on timing
I baught a timing gun and checked my timing, it apears to be around 20 and my car needs to be on 10. I can figure out where the bolt-down is for the distributor, or am I even looking for the right thing here.
Anyone else that has an 89ish firebird, or I assume camaro is the same thats gotten their fingers down there or can maybe let me know if im even looking for the right way to adjust the timing.
Haynes isn't being of any help what-so-ever.
*checks the tech area*
Thanks,
Type
Old Nov 27, 2002 | 12:13 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Did you disconnect the brown wire back by the blower motor before checking? That needs to be done or else timing will read advanced. The hold down bolt is tough to see but its down there--
Old Nov 27, 2002 | 12:38 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
MD, are you talking about the EST? My car is a 91 and the EST pigtail is on the back passenger side of the car, near the condenser..it's got a tan lead with a black stripe I think. Type, just unhook that connector and start the car...the car should start a little funny, might sound like it's about to stall at first..and an SES light should come on. Then your timing reading should be accurate... Without that unplugged, the computer tweaks the timing and throws your timing way off...mine read 18-20 with the EST connected.
Old Nov 27, 2002 | 12:51 PM
MDv6man's Avatar
Car: 1983, 1986
Originally posted by Nixon1
MD, are you talking about the EST? My car is a 91 and the EST pigtail is on the back passenger side of the car, near the condenser...
Yes that's the one... The circular thing bolted to the firewall is the heater/blower motor
Old Nov 27, 2002 | 01:36 PM
typevoid's Avatar
hmm..
Well, I disconneted the EST and checked the timing right this time. It's at about 9. I really hope this fixes some of the issues that I'm having. Mainly the backfires. If not can you guy suggest may be the problem with the backfires?
-Type
Old Nov 27, 2002 | 01:52 PM
MDv6man's Avatar
Car: 1983, 1986
I'd try bumping it up to 12 with the est disconnected. Then reconnect the est and clear the code. That should help.
Is the mark steady? If not, I would look at having the timing chain done as an unsteady mark usually means a stretched chain.
Do you have any exhaust leaks? Get them fixed as they will cause backfiring and rough running.
Just some suggestions...
Old Nov 27, 2002 | 02:39 PM
typevoid's Avatar
yeah, it apears to run it smoother now. It only back fires when its cold so Ill prolly have to wait till i leave the office to check if its still doing it. I noticed quite a change in the sound and the acceleration, hoping its fixed. I'll give an update once I get home tonight.
-Type
Old Nov 27, 2002 | 03:07 PM
Nixon1's Avatar
MD...so THAT'S what that big circular thing is! Lol, I never knew...
Old Nov 27, 2002 | 03:18 PM
MDv6man's Avatar
Car: 1983, 1986
Originally posted by GI*Joe
...And knowing is half the battle!
Old Nov 27, 2002 | 04:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Might also be a sign of a weak ignition or fuel system, too...
Old Nov 27, 2002 | 11:25 PM
Nixon1's Avatar
Yeah, I would sooner assume the ignition before the fuel system, although bad fuel filters are fairly common... Even though it may run better, I doubt it's still running nearly up to par... The car basically shouldn't backfire at all. Mine runs like @$$ but it's never backfired on me except revving it up, on the fall-back. I wonder if firing weakly on a cylinder or two would cause a backfire...
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
