attention ked85! (or anyone else who has done the 3.4 swap)
Old Nov 29, 2002 | 10:45 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
hey, will a 3.4 short block work under all of my 2.8 stuff? i've got brand new heads, would like to use my existing fuel delivery system as well as my heads. i am sure that i can find a 3.4 short block for next to nothing around here. what is involved with using my distributor also cause isn't the 3.4 equipped with a ignition pack thingy? thanks guys
Old Nov 29, 2002 | 10:57 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Yeah, the 3.4 block will work under the 2.8 top-end. I'd use the 2.8 timing cover also.
The 3.4 still has the distributor hole...it just has the oil pump drive in it. Pull that out...drop distributor in and you're done. The 3.4 will also have Cam and Crank sensors that were used with the DIS system. You'll need to either plug those holes...or leave them in but replace the o-rings at least.......there are tons of minor details but it's a straight forward swap.
Old Nov 29, 2002 | 11:15 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Yes, use your current 2.8 top. The 3.4l heads are the better heads unless you just had yours ported or so.
Use the 3.4l block, crank, cam, pisons, heads.
Use the 2.8l timing chain, oil pan, distrib, pullys, accessorys, intake, valve covers.
Old Nov 29, 2002 | 11:32 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I'm the exception
deracer
Apr 11, 2016 12:04 AM
gta90
Sep 15, 2015 04:00 PM
Todd84Z
Sep 4, 2015 08:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92projectcamaro
Aug 6, 2015 01:20 PM
