ALDL Usefulness
Old Dec 4, 2002 | 01:04 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
ALDL Usefulness
Ok...is there anything the ALDL terminal can't do? I mean, it can diagnose engine problems, it can force-lock the torque converter, it can manually control the electric fan (I HOPE this works with the engine ON as well!)....
Just wanted to know...what are some useful things this sucker can do that I don't know about? I'm a big fan of cheap, useful, manually controlled stuff...if I could control half of the crap manually with that engine, I would! So..any tips? I want a whole panel of switches on this thing if I can actually use em!
Thanks.
Old Dec 4, 2002 | 02:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ALDL Usefulness
Thanks.
Once a link is established to the ECM all kinds of good stuff becomes available. Data logging, diagnostics, control of many of the engine/powertrain devices, idle learn. . .
RBob.
Old Dec 4, 2002 | 08:36 PM
Nixon1's Avatar
Yeah, I've been thinking about doing some work with that..but I'd need a cable, a laptop, a prom burner...I just don't have that kind of technical skill or spare money. Not to mention I'd have no clue in hell as to what I was doing!
Anyone know any other useful things you can do the simple way?? (Connecting pins together to trip something)
Old Dec 4, 2002 | 11:56 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Nixon: DO NOT start your car with A and B jumpered. You can fry the PCM. You can jumper them after the engine has been started but the engine will be in "Field Service" mode. The SES will flash according to loop status and DTC's cannot be stored in the PCM.
Old Dec 5, 2002 | 12:40 AM
Camar_Hunter_c's Avatar
actually if your data logging, they have to be jumpered. But not straight out. It is done in the circuit that is made. They need to be so it will kick into DIAG mode and spit out data. It won't fry your PCM, trust me I have started the car with mu code reader installed, the SES light flashes like "hey Idiot, did you forget something?"
Old Dec 5, 2002 | 01:45 AM
Engine: LH0 3.1L
I know, i've started the car with A/B jumper before. PCM wasn't damaged but it ran like total $hit. Not cool......
Old Dec 5, 2002 | 08:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This is incorrect. Nixon1's '91 is SD with a '730 ECM. A link has to be established via two-way communication. 8192 baud is the only supported speed. The ECM will be transmitting idle chatter until a link is established. Jumping is not required or recommended while data logging as it will change how the ECM controls the engine.
RBob.
Old Dec 5, 2002 | 10:17 AM
RBob.
Incorrect. I have a 92 S/D as well. And the circuit calls for those two pins to be jumpered with a 20K?, no its a 10K resistor. So... While it may not be required, the circuit still connects those two jumpers.
Old Dec 5, 2002 | 10:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Sure is possible to put various resistor values across the pins but it is not required to data log. That is the point. And if data logging why would you want to change how the ECM is controlling the engine?
Here is the quote that I am correcting:
"actually if your data logging, they have to be jumpered."
RBob.
Azrael91966669
25
Jun 20, 2017 04:04 AM
fasteddi
Sep 2, 2015 10:29 AM
hectre13
Aug 26, 2015 08:17 AM
tmellott89
Aug 16, 2015 02:58 PM
sreZ28
Aug 14, 2015 07:48 PM
