not sure....
Old Dec 11, 2002 | 11:22 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
not sure....
i didnt really know where to put this post so i put it here.
ok under my hood there are alot of wires taht lead to nowhere, all tehy have are those plastick ends that i would assume plug into something....i just dont know where they would plug into. i know u guys cant really help me with this because u cant see the wires or anything. do any of u have any detailed pics of ur engine that show where they go???
thx in advance
Old Dec 12, 2002 | 06:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Where do the connectors hang out? Near the top of the engine, near the fenders, near the firewall, etc? How many wires, what color wires, etc? I take it that you have an '83? Was the car made in Canada? I think they had less strict emissions regulations than the United States, so you might have a United States wiring harness on a Canadian motor, leaving lots of wires unused. Just a guess. Either that, or if the wires are all near the top of the engine, then someone majorly messed with your carb!
MDv6man would be the guy to answer; he's got an '83 2.8L that he knows like the back of his hand...
Old Dec 12, 2002 | 10:15 PM
the wires are all over the place, by the alternater, distributer...thats all i can remember right now but its not a canadian made car. but i will talk to mdv6man. thx for the help
Old Dec 13, 2002 | 09:23 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
You Rang?
Thank you for the kind words Tom!
Only reason I know it so well was because the engine had to come out three times to fix prior mistakes!
But yeah I can probably help you...
Here's what I need you to do 83Firebird420...
Take some pics of your engine bay. I don't have a digital camera and it would be easier to see what is disconnected rather than photo every connection. After the pics are taken and uploaded, photoshop some numbers in for each connection and I'll be able to tell you where they go.
Old Dec 13, 2002 | 10:59 PM
KED85's Avatar
I'll bet you have factory AC, too.
Passenger side by front of the engine is a "electric plunger attached to carb" to keep idle "high" during AC Compressor operation.
One connection goes there.
Another.
Driver side front.
One is for water temp that goes to driver cylinder head.
THREE OTHERS
ONE is on side of carb that goes to the heater (gasket under carb) for the incoming "Cold air".
Two up front are for smog stuff. IF your FACTORY manifold has the fittings plugged up, need not worry.
Only worry about the carb heater wiring (as it's hot all time engine on) & the idle compensator for the ac, same story always have electricity going to it.
Of course some wires do go to alternator, those just fall into place.
Hope that sorts out your wiring.
Old Dec 15, 2002 | 01:37 PM
Another.
Driver side front.
THREE OTHERS
im gonna try to get a pic of my enign to show wat wires are loose, but thx for the help anyways
HasseO
May 22, 2015 06:52 AM
91Z06
Wheels and Tires
Oct 17, 2013 07:23 AM
ethan169
Apr 19, 2012 12:53 PM
chemicall
Feb 16, 2012 09:31 AM
