carb to mpfi swap in a 2.8
Old Dec 15, 2002 | 05:11 PM
84tagoin81's Avatar
hey my carb keeps giving me a **** load of trouble so i was thinking of the idea of changing it over to mpfi. can any one help with idea its not exactly somthing thats done everyday and i want to no if its possible. since i can ge tthe fuel injection system for free im opting for that befor i buy a new carb that may act up agian in a year. thanks
Old Dec 15, 2002 | 05:13 PM
Camar_Hunter_c's Avatar
its done all the time in the V8 world. You have the same stuff lined up.
You have to get all the sensors, engine wiring harness, I would suggest going to the 90-92 speed density system of the 3.1's(it will run the 2.8's just fine) then the computer with chip. Good cheap place to search... www.car-parts.com
Old Dec 15, 2002 | 05:20 PM
Comp... Under 40 search the later pages
1991
Engine Harness Wiring
Chevy Camaro 3.1L,AUTO,AC 990001 $100 Bayless Auto Parts USA-MO(Springfield) E-mail 1-800-397-9108
Sensors, parts store.
Intakes...run 30-40 a pop for all three
Ebay for fuel rail, or you may get from one of the searches on ca-part.
Old Dec 16, 2002 | 01:19 PM
84tagoin81's Avatar
little more help please
thanks for the site i love it however im still unclear on the exacr deatail of what is going to have to be done. you dont have to give me direction but just what will come off and be replaced by what if you would mind i would greatly appreciate it thanks jarred.
Old Dec 16, 2002 | 01:54 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Your going to need to find a donor V-6 top half, wiring harness, and computer.
I think you should change the heads for it to run properly, but I could be wrong.
You need the intake, the injectors, and all the sensors. Those will have to be all fitted into your old engine. Then you will need to pull out your old wiring harness, and replace it with the MPFI harness, Plus run this all the the computer you have to replace too.
You will probably have some alterations in your guages from then new wiring harness as well.
BUT the big problem will be the electric fuel pump that is inside the tank. You will need to drop the tank and install this.
With all this effort I would say either you take a weekend and do it all, or sell your current car, and search for an FI car.
Old Dec 16, 2002 | 05:47 PM
84tagoin81's Avatar
ok thanks thats helps alot. do u no anyone that acctuly did this or just going by experience and such?
Old Dec 17, 2002 | 02:04 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think there was someone on here 3 or 4 years ago that did it; but I can't remember. But yeah, basically, you replace everything off your motor except for the engine block and the heads and the water pump/alternator/air conditioning. If you can visit a junkyard, take a disposable camera and check out a MPFI v6, take a few pictures; everything will be pretty obvious after that.
Old Dec 17, 2002 | 03:21 AM
KED85's Avatar
Serious, IF you don't FULLY understand how to "swap inductions sytems over (including electronics)"
go rebuid the carb.
While you are at it, also have rebushed the Primary Shaft on the carb base.
It is the CHEAPEST EASIEST alternative to a full on induction system swap.
What changes....
let's say, the engine bay swap is the easiest.
Have you decided to drop the fuel tank to install the expensive dedicated electronic fuel pump system?
Or other alternative is just dump current ride & start high tech (MPFI vehicle).
Either alternative is not easy decision nor cheap I know.
Old Dec 17, 2002 | 03:44 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
http://www.tacreationsusa.com/new_page_3.htm#V6
there sell everythin u need to swap from carb to mpfi.. not too expensive either..
http://www.tacreationsusa.com/v6.htm
they also have? complete 94 3.4 w/ 5 speed tranny ($850 & i was quoted $500 for shipping to cali from fl)..
:burout:
-mike (loomdog)
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
E Rod
Aug 28, 2015 05:17 AM
theurge
Aug 21, 2015 12:46 PM
86Base
Aug 8, 2015 01:34 PM
