Size of 2.8 injectors on 85 Camaro
Old Dec 15, 2002 | 06:13 PM
Shok's Avatar
Anyone know the size of the injectors for an 1985 camaro with the 2.8 mpfi?
It seems mine are leaking and a friend of mine has some from his grand national that he knows are good that I can have if they are compatible. He just changed them out cuz he turned up the boost.
I know this may be reaching but doesn't hurt to ask since I'm low on cash.
Old Dec 15, 2002 | 06:21 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
should be 13lbs
(125hp x .50) / ( 6 x .80) = 13.08
Old Dec 15, 2002 | 06:31 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Dale, shouldn't that be 135hp? I thought the 2.8's used 15 lb'ers........either way, I guarantee GN injectors will be too big.
Old Dec 15, 2002 | 06:48 PM
Dale's Avatar
Engine: 350 S-TPI
I belive the 2.8l was 125hp, and the 3.1l was 140hp.
But yes, GN injectors will be to big. I belive I read somewhere on here a guy put 17lb injectors from a 3.4l in his engine and always got the "rich" code.
Old Dec 15, 2002 | 07:48 PM
Shok's Avatar
Ok I guess that settles that, thanks for the info guys.
Old Dec 15, 2002 | 08:53 PM
camaro89dude's Avatar
2.8 is 135 hp
Old Dec 16, 2002 | 12:48 AM
Engine: LH0 3.1L
Yeah, the 2.8 was 135 hp. Also, I have 3.4 injectors in my car and I get the code 45 every once in a while.
Old Dec 16, 2002 | 07:21 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Well, the 'slick' thing to do, would be to get teh 3.4/3.8 injectors (or whatever other oversized ones you could find) and reprogram the fuel maps according to the new fuel flows.
Old Dec 16, 2002 | 09:09 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
so V6 injectors are oversize and V8 ones are smaller ?? in actual size ??
Old Dec 16, 2002 | 01:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You mean size as in the outside dimension? They should all be the same size; inside is what changes. You should try to have those injectors sent out to Rich Jensen at http://www.cruzinperformance.com for a "real" cleaning- he disassembles them, tests them, cleans them, and puts 'em back together to do a flow-test. The service is 100% worth it; I had it done a few years ago, and it made an instant improvement in the car! Plus it cost less than buying 1 new injector!! Rich even installs new o-rings and pintle caps on the injectors.
You could send out the GN injectors, and put them in when you get 'em back. This way you can keep driving your car. Or... you could swap the GN ones in (and you'll run rich for a while), and send out your originals to Rich to see how the tests work out. If you shoot him an email (from the website), tell him your situation; he'll probably be glad to help you figure out the best "plan". I'm not sure if a simple cleaning will fix a leaking injector. I know, too, that his website says he can swap out injectors that don't flow-test within spec; maybe he can swap out a faulty injector for you?
Old Dec 16, 2002 | 04:01 PM
Shok's Avatar
He can do it for less than the price of a new injector? Last time I checked at kragens an injector was like 70 bucks, so thats a really good price for a cleaning. I sent injectors from my GF's corsica to RC for cleaning last year and it was a few hundred IIRC. I'll email the guy and ask.
Oh here's why I think the injectors are leaking. When the car has been running for awhile and you shut it off for like 15 mins and then try to restart it again it has to crank a long time b4 it starts. I can hear the fuel pump kick on so I don't think the relay is the prob there, I think its the injectors leaking while the car is off and sorta flooding things. That friend of mine with the GN agrees and had the same prob and new injectors cured it. Of course b4 I actually pull an injector I'll do a full tune up, but it seems like the car was tuned up recently.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Linson
Aug 21, 2015 02:12 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
