Alternator Question
Old Jan 6, 2003 | 04:58 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Alternator Question
OK...I am going to re-wire my charging systemNew battery cables,new braid engine ground strap.The one thing I need to find info. on is the wire coming from the battery hot lead to the junction bloack on the side of the radiator.Does anyone know what gauge GM used to go from the battery to the block and from the block to the alternator.I want to use 8 gauge cable, but if the factory only used 10 gauge, I dont want to do an overkill.Has anyone done this, and if so, what size wire didi they use?Thanks alot guys.
91 RS 3.1 V6
Old Jan 6, 2003 | 10:45 PM
KED85's Avatar
I know the point you are referring to.
Do yourself a favor.
OVERKILL IT!
It's truly in your favor.
OR hit the wrecking yards for "samples"
Old Jan 7, 2003 | 12:35 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Don't know the gauge size but you won't hurt anything by going to a bigger wire. Just don't go smaller......
Old Jan 7, 2003 | 05:30 PM
ken3983's Avatar
Thanks guys.I will probably go with 8 gauge wire from mattery to block and block to alternator.Better an overkill rather than an underkill.I might put a new starter on it.Still has the factory one.Wont hurt to put on a new one.Later dudes!!!
Old Jan 7, 2003 | 11:26 PM
KED85's Avatar
IF the starter works why waste the money for nothing.
Buy your girlfriend dinner instead!
Atleast you won't get dirty hands
Cornholio7979
Sep 20, 2018 02:31 AM
dutch930
Sep 11, 2015 06:58 AM
Cleotiz
Aug 23, 2015 12:07 PM
redmaroz
Aug 16, 2015 11:40 PM
