Heads
Old Jan 8, 2003 | 08:49 PM
86camarodriver's Avatar
Heads
Anyone know of anyone who sells HIGH FLOW heads with the larger valves for our engines besides GM performance parts?
David
Old Jan 8, 2003 | 09:07 PM
AFreaknGoodTme's Avatar
Supersix Motorsports. Here a forum on when they were being developed: http://www.supersixmotorsports.com/f...le=Engine+Tech
Here's an info forum after their completion: http://www.supersixmotorsports.com/f...le=Engine+Tech
Heres their home page with contact info: http://www.supersixmotorsports.com/
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
A little something I found out a while back
edit: you beat me on the html draw , but i'll be back.....
Old Jan 9, 2003 | 10:01 AM
WOW I love the heads, I posted on the second link, thanks man
David
Old Jan 10, 2003 | 09:57 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
how big are you looking to go on valves? GM made two different heads for the 60* v6s. one type had 1.60" int. and 1.307" exh. and the other type had 1.718" int. and 1.425" ex. you should be able to run across a set of these heads (with bigger valves) if that's the size you're looking for then port and polish then and have a decent set to bolt on. there is a pretty noticable difference in the port sizes on the two types.
Old Jan 10, 2003 | 10:37 PM
KED85's Avatar
If you purchased the OTC 3.4 this would be a moot point.
At $1,700 total cost it's worth it and it's all brand new w/12,000 mile warranty.
Only diff in a 2.8/3.1 MPFI head compared to a 3.4 SFI head is the more meat in the valve spring pocket area & better springs.
Invest in the GM Performance Parts book for a measly $6 to find out the answers
Any GM dealer.
Probably can negotiate the OTC 3.4 price down, too, same time.
Can't beat brand new.
My response isn't dealing with the carb'd 2.8 head, at all.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
