Backfire Woes
Old Jan 11, 2003 | 07:20 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Backfire Woes
87 2.8 MFI
Backfires between 1-2 shift from about 4500 RPM.
What I know is good:
Plugs, Wires, Cap/Rotor, Ignition Control Module, Timing, Vac lines.
What has been suggested:
02 Sensor, MAP sensor, Take it to a shop.
According to my Autoxray scanner... the car stays in open loop... until it's running down the freeway then it's in closed.... once I let off the gas coming to a stop it's in open for the whole city drive.
The idle doesn't come down very fast at all.
Any ideas?
Old Jan 11, 2003 | 08:03 PM
camaro89dude's Avatar
Definately replace o2 sensor, because a bad one can keep you in open loop. Do that first, its cheap and easy, and then tell us what happens.
Old Jan 11, 2003 | 11:52 PM
WaynesRS's Avatar
If it still backfires after the 02 sensor has been replaced , I think you can test your MAP with a multimeter . I know you can test a MAF with a multimeter . I don't know how , but Tom knows .
Old Jan 12, 2003 | 12:54 AM
Slow2.8's Avatar
how much/easy is it to change the o2 sensor? and what exactly does it do?
Old Jan 12, 2003 | 02:00 AM
AFreaknGoodTme's Avatar
If I remember correctly they are around $20.
Tip for removal-- run the car and get the exhaust warm to hot. Use gloves and be careful- this will expand the bung that the o2 sensor screws into and will make removal easy. They are next to impossible to get out when the exhaust is cold.
Old Jan 12, 2003 | 08:41 AM
Mine is in the in the area of the pipe right before where the catalytic converter would be, after both left and right side pipes come together.
I think it just unscrews.
If your o2 sensor is bad, it can give false readings about how much air is going through your pipes and keep you in closed or open loop mode.
Old Jan 12, 2003 | 10:55 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
O2 is totally easy...but like AF said, hard as **** to get off without warming the pipes. Trust me..I tried....and succeeded....*** that was painful. And yeah it just unscrews..it's in the Y-pipe...sticks out horizontally. Just unplug the connection..it's way up top, just follow the thin line. With the pipe nice and warm, screw the old one out. Take the cap off the new one, and CAREFULLY insert it and tighten it down with a deep well socket. Be EXTREMELY careful with your new O2 sensor..they're very sensitive and can be damaged easily. Removing my old one completely broke it. Friend tried to use it and it didnt work at all. After tightening it, reconnect the pigtail and reset your ECM. Bam, done. Shouldnt cost any more than $20 for one..I got a Bosch replacement.
Old Jan 12, 2003 | 10:59 PM
Nixon1's Avatar
By the way.. Computer needs several things to check out to go to Closed Loop operation. One of which is that it has to receive a signal from the O2 sensor. If it doesn't, it can't switch to closed loop because it doesn't have enough data to run the car properly in closed loop..could cause a stall..therefore, the computer being as smart as it is, runs only in open loop.
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
