junkyard 350
Old Jan 23, 2003 | 07:47 PM
firebird13's Avatar
junkyard 350
Would it be really stupid to find a 350 for realy cheap from a junkyard? and build it up? or would it be a good cheap idea?
Old Jan 23, 2003 | 08:25 PM
Camar_Hunter_c's Avatar
All depends on YOU.
IF you can find a good block, sure good idea. But you can usually get a good engine outta the want ads for around 2-300. Why go through the trouble of a junk yard?
NOW if you are going to "truely" build the engine, all you wopuld want is the block, maybe the crank. Again depends on what you want to have done.
If you just want a cheap, quick swap thing, search the want ads, and try to find the trans first. No matter what is said, REBUILD IT. Get that first.
THEN get the engine. The trans will give t you the least rouble if it needs rebuilt. And if the engine needs work, you can get that done afterward. But you can always take solice that you have a good trans ready to go.
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
Vojtush31
Oct 11, 2015 01:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
