Switch to Speed Density
Old Jan 27, 2003 | 09:41 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Is there a way to do it for the 2.8l V6 in an '88 camaro RS. Does anyone know if this is "emissions" legal in California? If it's possible, how would I go about doing it?
Old Jan 28, 2003 | 07:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Switch to Speed Density
Yes it is possible to convert. I wouldn't know if it were emissions legit in California. The one difference that I am aware of is the EGR. The 90-92 SD setups use a digital EGR. So you would have to swap that over too.
Just get the EGR from the same car you get the ECM & harness from. Grab the MAP sensor also.
I do know that the TPI guys that do the conversion's are quite glad they did.
RBob.
Old Mar 29, 2003 | 03:40 PM
USMCTransAm's Avatar
Sorry, but the last time I checked, anything that didn't come stock on YOUR car (meaning your exact car, not any of the same make/model) is illegal in California.
(I won't even get started on my opinion of THAT state.........)
But if I were you, I'd assume that no one doing the inspeccion is going to care, or even know the difference.
BRoss99
Aug 10, 2025 05:08 PM
Steve78LT
Feb 24, 2016 12:15 AM
Thornburg
Aug 27, 2015 08:28 PM
Keith5
Aug 27, 2015 04:37 PM
86Base
Aug 8, 2015 01:34 PM
