89 RS 2.8, rearend POSI?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
What rear end came in an 89 RS with the 2.8 engine? the tech data page says 3.42..would that be a posi rear end?
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Nope, open ended. You think GM is going to spend extra money for a posi on our cars??? Cheap a$$es. Placing relays all over the engine compartment instead of making them in one single spot... and FUSES too.. why couldn't they do that??
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
my 89 RS has posi, im not sure of the gears, ive heard everything from 3.73's to 2.73's to 3.23's..but its posi...
And another thing... who's bright idea was to use TORX bolts on a water pump?? Aren't regular bolts adequate to hold it in?? Same thing with the cooking ignition coil over the passenger manifold?
I'm a little bitter, just got college rejection letters.
Car: 1986 Firebird
Engine: 2.8 V6
I believe Torx is better suited for an assembly line... but not too good for the home mechanic, especially if you snap a torx bit off. Torx started after '86. I've got regular bolts on the water pump!
KO1
16
Oct 15, 2015 05:00 PM
