tranny problem...help meeee
little by little my tranny wouldnt shift till hiiigh rpms...then somtimes it would shift normal...then one day it died at a red light, started right back up, but every gear is neutral...a friend told me to replace the governor...i did...still doing the same thing
although i did have a little trouble getting the new governor gear onto the gear assembly, could i need to replace the whole assembly...or just the little gear? btw...i have an 87 v6 w/700r4 tranny
thanks for the help
smurf
although i did have a little trouble getting the new governor gear onto the gear assembly, could i need to replace the whole assembly...or just the little gear? btw...i have an 87 v6 w/700r4 tranny thanks for the help
smurf
Car: 1986 Firebird
Engine: 2.8 V6
Go ask on the Transmissions forum. Your transmission is the same model and has the same internals as the v8 transmission; v6 transmissions just have a smaller case. Doesn't sound like it'd be the governor, though. Either way, the trans forum can help.
Car: check
Engine: check
Transmission: check
Originally posted by Xceleratemaro
tom are you saying that you cannot hook up a smallblock up to a 90-700r4 ??? bc i was planning on doing it here soon!!! Please let me know
700R4's are used on the V8.
RBob.
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Driveshaft
well son of a b!tch dammit
thanks i didnt know that if you were to replace the trannies with a v8 one would the drive shaft still line up??
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
