82 berlinetta engine swapout
Old Feb 2, 2003 | 05:11 AM
TimOld82Camaro's Avatar
Hi There..
I own a 82 Berlinetta and sometime this year I'm looking at replacing the engine. I want replace the V6 with a V6. From what I have found the 2.8L engine was used in many other vehicles.
I called a wrecker and I was told about 500 bucks (Canadian) for a used engine. I then called a few weeks later and asked about a 2.8L outta a S10 and I was told 400.
I guess saying camaro added about 100 bucks to the bill.. so I was wondering.. what other V6 engines can I put in my car? Im not to sure about the tranny but its the original that came with the car and the engine is also the original. What engines can I bolt in that will work with this tranny? If you say the 3.4L or others can you also tell me which car/truck and year its from.
Thanks for your time guys.. Tim. VE5TNC
Old Feb 2, 2003 | 10:58 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Well technically the 2.8 for the camaro makes more power. It has aluminum heads, and breaths better. The bottom of the S-10 and Camaro engine are the same, but the top half is a different story. therefore probably making it more expensive to purchase.
Other engines you can swap in are the 3.1 90-92 camaro, and 3.4 long block from the 93-95 camaro's. FWD engines will not work, there bolt hole pattern to the transmission is different.
Old Feb 4, 2003 | 11:44 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
The Camaro and S-10 motors are the same. Both come with Iron heads. Any more power from the Camaro vs. S-10 is due solely to the difference in induction systems (MPFI vs TBI). The only 60* V6's that got aluminum heads were the ones used in FWD cars after 1987. They will not work because of the starter and motor mount locations. The trans bolt patterns are the same.
Old Feb 4, 2003 | 02:50 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
aluminum heads that came on the 2.8's in camaros,?!? Where?!?!?! what are you smokin' man
Old Feb 4, 2003 | 03:02 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Re: 82 berlinetta engine swapout
Why? (Seriously, just curious)
Old Feb 4, 2003 | 03:16 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Price and ease of installation. No change of tranny, wiring, radator, motor mounts, suspension, smog police, price of insurance, OUTRAGIOUS GAS PRICES. If I think, I could find more.
Go for the 3.4l from 93-95 bird/camaro.
Use 3.4l.....
Block, crank, cam, pistons, heads.
Use 2.8l.....
Intake, timing chain cover, valve covers.
An engine that old you will need to get a flywheel from a 88 up engine. Oil pan, um?? Will have to ask one of the more advanced engine swapers on that one.
Will have to tweak carb, or get new.
Advise new timing chain while down that far.
Old Feb 6, 2003 | 06:18 PM
Although its not a classic.. I would like to keep it as close to stock as I can. Cost is another thing.. I dont have a pile of cash to start switching out the whole drivetrain. I figured the simplest way to keep my car on the road is to swap the motor.
Besides.. I dont race.. dont have nothing to prove to anyone.. I have 3 kids to feed.. work is only 4km away and gas is going up
Thanks for your replies sofar guys.. Tim. VE5TNC
Old Feb 6, 2003 | 06:46 PM
Joe_L's Avatar
Car: 1995 Z28
Sorry there buddy, one of those poor moments of clarity.
Okay so we don't have aluminum heads. I know that, but our 2.8's heads have to breath better. Is there something different?
Old Feb 7, 2003 | 06:39 AM
MDv6man's Avatar
Car: 1983, 1986
The only yearb that may have been true was 1985. That was the first year that F-bodies received the heads with the larger valves (previously only available on the 2.8 HO in the Firebird SE). The only difference in S-10 and Camaros are the induction systems.
Old Feb 7, 2003 | 06:55 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
incorrect, they have the same trans/engine bolt pattern
why they wont work is:
starter location (opposite side, unless you want to cut your tranny a little bit)
motor mount locations- FWD blocks were designed for dog bones
Old Feb 7, 2003 | 10:40 AM
Joe_L's Avatar
Car: 1995 Z28
Okay, cool.
I just assumed that our heads were better because I read a few S-10 2.8 swaps posts, and they said to use the bottom half, but make sure you change your heads. But I guess that was just poor info.
TealRS, thats cool, I thought it was said that the bolt hole pattern was different as well. But your a mechanic so I will trust you on this. I knew about the starter and mounts, but I assumed the bolt hole pattern was the biggest problem. Bad info. again. But that is what this board is for, learning.
Old Feb 7, 2003 | 11:29 AM
Learning.. so far I have got my carb fixed.. bad idle fixed.. and some of my wiring fixed up because I found this board..
There is a 3.4l from a Firebird at the wreckers.. going to check it out later today I hope.
Thanks for the help guys.. Tim VE5TNC
Old Feb 7, 2003 | 12:10 PM
pontiac/buick/gmc apprentice for one full year where the most plentiful engine was the 60* V6 be it 3.1 and 3.4
i helped pull enough transmissions and engines from FWD cars to be sure that it is the same
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
