Anyone else have this problem
Old Feb 2, 2003 | 08:56 PM
92V6Heritage's Avatar
When i hit the brakes, the gas meter goes down to E, but only when i press them quickly. And if i accelerate it'll go up a little bit. Also, like a 1/4 of the middle of the Speedo doesnt light up. Anyone know what im dealin with here? Thanks
Old Feb 2, 2003 | 09:40 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Gas guage in mine is VERY sensative/touchy.
Everything lights up on mine.
Old Feb 2, 2003 | 10:07 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Light in the back of the speedo area probably burned out...
All the gauges on these cars seem to be very sensitive...mostly the tachs, gas gauges, and alt output gauges. My gas gauge needle moves quite a bit depending on whether I'm accelerating, braking, or cruising. Trust the cruise reading...everything else is off.
Old Feb 3, 2003 | 12:15 AM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
LOL, my gas gauge is the only one that bounces around. It looks like its on a trampoline going on a relativly smooth road. You would have thought after a few years of that occurance GM would have tried to fix the problem.
Old Feb 3, 2003 | 12:28 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
Remove the cluster and replace all the bulbs since your there. Then clean and tighten the fuel gauge connections even though they seem tight. And lastly be sure there are no bad or missing fuses. A fues that isn't in the circuit being tested that is bad still may cause a feedback in the troubled circuit. hope that helps...
Old Feb 3, 2003 | 01:24 PM
Slowmaro95's Avatar
From: Straight outta the red light district of Highland
Car: 2001 SS
Engine: guess...
Transmission: 4 spd w/OD
Axle/Gears: 3:73 Posi
Well i know that most cars have "floaters" in the tanks so every time you hug a steep turn or basically tip the tank at any angle the needle will fluxuate. It's just common place. But it would be a good idea to think electrical and check the hook ups.
-D
95 camaro
3.4L
flowmaster w/ 3" tips
Green with gold stripes
Old Feb 3, 2003 | 02:43 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
agreed the "floater" sending unit is what goes bad 99.9% of the time nothing within the gauge panel itself
Old Feb 3, 2003 | 05:51 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
floater is gona on my 87.....i think it looks cool bouncing around....
Old Feb 3, 2003 | 06:08 PM
Nixon1's Avatar
Cool til you run out of gas on a 'full tank'.... Mine bounces just a tad...it's my oil pressure that bounces the most. 20-40 psi warm.....not to mention my tach reads, at a MINIMUM, about 5000-5500 rpms. Whenever I TAP the pedal, it flies past 7000 and sits at the bottom.
Old Feb 3, 2003 | 07:10 PM
Car: 85 Camaro SC
Engine: V6
heheh I guess I'm lucky to just have the trampoline gas gauge. And all the others work perfectly.
Old Feb 3, 2003 | 07:41 PM
Xceleratemaro's Avatar
i floor my car everywhere to get better gas milage lol just kidding but it looks that way every time i floor it and the gage gose up he he he, the worst part is the f*cking 141 per gallon
dammmmmmmm
Old Feb 4, 2003 | 12:06 AM
icebird_1981's Avatar
mine to, hard brake go down, slam gas go up.
Old Feb 8, 2003 | 02:15 PM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
i have noticed that when i am coming to a stop my rpms dip down
what could this be?
Old Feb 8, 2003 | 03:32 PM
Nixon1's Avatar
Uhm.....do you mean dip down like to the point of stall? I ALMOST laughed my *** off at this until I realized that it could be a real question. If it's near the point of stall...could be several things..my main guesses would be fuel filter or sticky IAC valve. Fuel filter-Replace. Sticky IAC valve-Remove and carefully clean with carb cleaner.
Old Feb 10, 2003 | 12:58 PM
Slowmaro95's Avatar
Car: 2001 SS
Engine: guess...
I have the same prob with my 3.4L. I was told it could be the mass airflow sensor. I'm kinda interested in what it is. I just let my car warm up in the winter longer and the prob disipates.
Old Feb 10, 2003 | 08:18 PM
Nixon1's Avatar
He has no MAF sensor, he's speed density...MAP instead.
MAF is a big lunky sucker fitted in the air intake tubing..restricts air into a section of it to vibrate or heat or something a filament up, which tells the computer how much air is incoming.
MAP is an indirect method of air measuring...a sensor is hooked into the back of the intake manifold that measures air intake by something to do with the vacuum or air density or volume, I forget..and compares that data to a chart programmed into the computer's memory, and uses that. MAF disadvantages are it restricts flow to measure, BUT it also is flexible in that it will work accurately with extra airflow and extra power made. MAP I believe isn't flexible enough so if you start making a sh*tload of power, it won't calculate right....
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
