87 2.8 V6 ???
Old Feb 18, 2003 | 03:24 PM
E-Z Rollin's Avatar
87 2.8 V6 ???
I have an 87 2.8 with tbi and auto-trans that I'd like to install cranes #250531 cam into[previously in 83 with 4bbl]. The specs are 204/427 216/454, card says 80-up,smooth idle,daily usage,light towing,economy,but crane's online spec card says"emission controled without computer". The tech at crane said[not to convincingly] that it should be o.k. The only mods I plan to make on this vehicle is the cam swap and maybe a catback freeflow exhaust. Anyone using this cam or having done extensive mods to a 2.8,I would appreciate your input !
Old Feb 18, 2003 | 03:56 PM
LT1guy's Avatar
Car: 1987 Trans Am
I would agree with the Crane rep...its less radical than the cam Redraif is running, and hers runs fine with the computer 9also 87 2.8).
Old Feb 18, 2003 | 04:06 PM
E-Z Rollin's Avatar
Any post with Redarif's engine or cam specs ?
Old Feb 18, 2003 | 04:10 PM
LT1guy's Avatar
Car: 1987 Trans Am
Its on her website I believe...
http://www.cardomain.com/id/redraif
BTW its overcammed...it killed some low end torque, but the midrange and top are a lot better. Gas mileage also improved a lot, amazingly. It still has some tuning issues, but it doesn't code and sounds pretty mean for a V6.
Old Feb 18, 2003 | 04:22 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Page 27 has the specs...
http://www.cardomain.com/member_page...191601&page=27
Old Feb 18, 2003 | 06:08 PM
E-Z Rollin's Avatar
Thanks for the info;my main issue is whether the cam will cause problems with the computer and drivability as I don't plan on any other mods other than the cam and cat back exhaust. I would be interested in hearing from others that have done mods to a 2.8.
Old Feb 19, 2003 | 08:46 AM
LT1guy's Avatar
Car: 1987 Trans Am
We had to raise the idle speed slightly (adjustment screw on the throttle body), but that was the only issue. Drivability is actually better now IMHO.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
