Throttle body coolant bypass
Old Feb 19, 2003 | 05:14 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I read on another site that the coolant going into the throttle body actually keeps the TB warmer (so it doesn't freeze during the winters, I guess). What the author did was disconnect the coolant lines from the TB and just run a hose to reconnect the coolant lines. He then plugged the inlet and outlet on the TB and claims that he got a few more horses and feels much better throttle response. Has anyone done this and did you feel any difference.
Old Feb 19, 2003 | 05:41 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
i did it recently, but noticed no reall difference. It does how ever make it easier to work around and under the plennum. I plan to make it look really nice pretty soon, i just don't have the time right now
Old Feb 19, 2003 | 08:19 PM
Xceleratemaro's Avatar
o my godddddd PLEASE DONT BRING THIS SUBJECT UP AGIN. we have had so many flam wars in here about this....if you are interrested in doing this "mod" then go to the https://www.thirdgen.org/newdesign/t...ntbypass.shtml
this will explain how to do it if you wish.....
i did this i got 2 results.....my tb froze in south carolina....in january, it will not give you any hp at the rear wheels..but with other mods it may help you....although i did notice when i drove my car b4 the bypass the intake would get vary hot...now it dose not...
this is a trade off........you will get 50/50 results....
hope this helps
Old Feb 19, 2003 | 09:24 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Re: Throttle body coolant bypass
Check out this thread for another option (There is a picture- then further do the post is a detailed parts list.) https://www.thirdgen.org/techbb2/sho...hreadid=154295
Old Feb 20, 2003 | 12:53 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
i didnt feel any increase either.... but no money was wasted! i dont have to worry about it since i live in LA, but (as mentioned above) it may prove to be a hassle in colder climates
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Dec 6, 2015 11:25 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
