90-92 3.1L Injectors
Old Feb 26, 2003 | 10:11 PM
zoomzoom's Avatar
Was wondering if you guys/gals that have had your cars for a while could tell me if these injectors are "known" to be problematic/unreliable? Also, are these injectors the same ones used in the 2.8L motors and are they rated at 12lbs/hr and the 3.4's at 15lbs/hr?
ThanX
Old Feb 26, 2003 | 10:15 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
The injectors in our cars are Multec...they aren't GREAT injectors, but they're decent I believe. Although Ford injectors are much much better. 2.8 and 3.1 liter injectors are probably the same lb/hr rate..although 12 lb/hr sounds very low to me....but maybe that's just because I'm used to my V8 that has 19 lb/hr stock...
Old Feb 27, 2003 | 07:06 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
2.8l=13lb
3.1l=15lb
3.4l=17lb
According to cruzinperformance who cleans injectors says that the multitecs are some of the worst injectors out their.
I am still trying to find a ford product that has 15lb injectors in it
Old Feb 27, 2003 | 11:34 AM
zoomzoom's Avatar
Thanks for the input guys I've been doing some research in the mean time and downloaded the ACCEL ACCEL DFI (1.7MB) catalog at : http://www.mrgasket.com/accelmain.html and they list fuel injectors for all our 60° V6’s (and a bunch of other cars also, 15lbs on Fords, Dale ).
They show the stock replacement injectors for the ’85-92 2.8/3.1 in the F-Bodies to be 15lbs units. They also show “Plus 1 thru Plus 3” performance increase levels that are 17/19/21 lbs/hr respectively. I can get a set of 17lbs injectors from Summit for around $175.00. I think that would be a good choice for my engine (I used their injector sizing formula and guesstimated as to some of the variables) due to the low restriction intake/exhaust I’ll be using. Opinions??
Also, has anybody used the Accel injectors? Is their quality any good??
ThanX
Old Feb 27, 2003 | 12:03 PM
Dale's Avatar
Engine: 350 S-TPI
I know I put 17lbs in my 3.1l and it ran rich, and used more gas. Maybe you will have better luck then me.
I will try and find whatever you downloaded and take a look
my91rs and a few others have accell units in their cars. Alot of v8 guys do also. They seem to be the favorites of aftermarket injectors.
Old Feb 27, 2003 | 12:54 PM
Nixon1's Avatar
I'd be skeptical of upgrading injector size. Even with a better intake and exhaust, I honestly don't think you'd gain any power out of larger injectors without any internal engine work. I think you'd actually run rich like Dale did and LOSE power. I'd stick with a stock size unless you plan to upgrade the car quite a bit. Then...I forget how Chevy injectors and the MAF work...but on Fords, you have to upgrade the MAF AND injectors with compatible units. For example, I have 19 lb/hr injectors stock..I couldn't throw 24 lb injectors in on the stock MAF...they wouldn't work right..so I'd have to buy an MAF specifically calibrated for 24 lb/hr injectors. Pain in the *** if you ask me....
Edit: Ignore the MAF comments....you don't have an MAF.
Old Feb 27, 2003 | 07:01 PM
Erin91RS's Avatar
Car: 91 RS
Transmission: 700-R4
argh...my injectors went at 51,000 miles then the other 3 went at 53,000. I now have AC delco injectors in my car and they really smoothed my idle out. I don't know details on them except they cost $119 a piece
Old Feb 27, 2003 | 07:03 PM
Nixon1's Avatar
$119 PER INJECTOR?? Christ..where'd you get that quote from?
Old Feb 27, 2003 | 07:18 PM
Erin91RS's Avatar
Car: 91 RS
mechanic....i was pissed cuz I could ran down to summit racing and bought a set six or like $250
Old Feb 27, 2003 | 08:18 PM
Nixon1's Avatar
Yeah..you got ripped BIG time man. I had a mechanic put in a set of brand spankin new Ford Motorsport 19 lb/hr high flow injectors (I assume high flow means a better pintle design or something)...he ordered them from the local speed shop, AutoPro Racing...it was $250 for a set of 8. Ford wanted $900 for the same exact set.
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Randomtask2
Sep 10, 2015 08:37 AM
