underdrive pully
Old Mar 16, 2003 | 10:36 AM
white89v6's Avatar
underdrive pully
how do you get the center bolt on the crank pully off. Thanks
Old Mar 16, 2003 | 11:22 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
counterclockwise just like the others. Best to use an impact gun. If you don't have one then leave the serpentine belt on for extra resistence and hold a wrench in the tighted mode on one of the four outside bolts for reverse resistence as you try to break it loose.
Old Mar 16, 2003 | 03:04 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Correct, I used impact. 19mm bolt I belive.
Old Mar 16, 2003 | 07:13 PM
white89v6's Avatar
I got it about 15 min after posting. used a vice
grip to wedge aginst the water pump pully.
Thanks guys anyways
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
bryaniskoo
Oct 1, 2015 03:18 PM
italiano67
Sep 22, 2015 08:42 AM
Navy8125
Aug 22, 2015 07:13 PM
