Fuseable Links
Old Mar 17, 2003 | 06:06 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Fuseable Links
Can these be replaced with a standard one??? Please respond asap!
Old Mar 17, 2003 | 07:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You mean replaced with a standard fuseable link? As long as it's the same rating... which one got fried?
Old Mar 17, 2003 | 08:27 PM
Dale's Avatar
Engine: 350 S-TPI
Well, its not fryed, but the wire is now to short for a standard new lug on the end.
Its the "16" that has one orange on one end, and two red out the other end.
I am wondering if I can replace it with a waterproof flat blade style holder.
Old Mar 22, 2003 | 06:18 AM
KED85's Avatar
ABSOLUTLY NOT NO NEVER CHEAT!
You'll fry set the wiring on FIRE IF anything ever happens.
FOR A $2 fix?
Want one for FREE!
I have a spare when I MELTED THE WIRES TO STARTER BY HOOKING UP BATTERY WRONG!
Opps!
I replaced, soldered ends, use heat shrink wrap over the soldered splice ends.
NEVER CHEAT ON FUSIBLE LINK WIRING NEVER!
Old Mar 22, 2003 | 05:08 PM
devianb's Avatar
What does the fusible link look like?
Old Mar 22, 2003 | 06:13 PM
KED85's Avatar
The easiest way to explain is actually on your own vehicle or the parts store.
Let's go to the car first.
Find the two wires to the starter.
FUSIBLE LINKS
Can you tell by looking?
I couldn't either.
How to tell they are fusible & they do the job!
EASY, DO LIKE ME THE IDIOT!
Cross the battery cables on your battery and hit the key!
They turn to melted goo by the time you catch on ya screwed up BIG TIME!
AND the SMELL!!! (all sing now.....OOHHH THAT SMELL!!!)
Instant viewing equals a burnt to the crisp outter plastic coating & visible wires. Wave away the smoke first!
How to find at parts store, ask someone, cause they look just like regular THICKER wire.
And they come, just like fuses, in various "ratings".
Serious, this fusible link wiring is a protection to prevent complete electrical wire harness meltdown which equals wire fires which equals (in a Corvette example) a molten pile of melted fiberglass over steel frame plus ya get to examine the steel cords in radial tires and those steel springs in the seats!!
Serious on the wires to starter as the best in your car example.
Those are the ones I fried when I crossed my battery cables on the Blazer 3.4 swap project! OPPS!
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
