Holley Ignition Module Install??
Old Mar 22, 2003 | 01:59 AM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
ok so i got these two parts and the midule came with no install instructions!!!
HELP!!!
where does it go!!
Old Mar 22, 2003 | 08:55 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
On my 84 it is under the distrubter cap under the rotor button.
Old Mar 22, 2003 | 09:29 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Same here. Need a 5.5mm socket, or a 7/32 socket. And make sure you use ALL the heat sink goop.
Old Mar 22, 2003 | 05:07 PM
devianb's Avatar
It has been a while since I put in my Accel module, but it is pretty simple.
Just take off the distributor cap and rotor (don't forget to put the rotor back in the exact postion).
Unplug the connections to the module.
I can't remember if there are bolts holding the module down, if there are then just unbolt them.
Unplug the module and put in your new one
My Accel module came with silicon lubricant to spread on the side of the module that touches the metal to dissipate excessive heat.
I don't know if you need that, but it wouldn't hurt.
Then just plug it the module in and reconnect everything.
It really is simplier than you think.
Old Mar 22, 2003 | 06:54 PM
Engine: 3.1
well im also installin the 50,000 volt coil on top of it so ya....
Old Mar 22, 2003 | 08:16 PM
Dale's Avatar
Engine: 350 S-TPI
Right,take the cap off, dx wires going to it, unscrew via sockets listed in my above post. Smeer goop on, sit in place, screw back down, plug up wires, put cap back on.
Then on to the next project
Old Mar 22, 2003 | 09:29 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Could you let me know if you feel any difference with the new module???
Old Mar 22, 2003 | 09:46 PM
KED85's Avatar
HAVING GONE THRU SIX MODULES OF VARIOUS BRANDS
I can honestly say NO DIFFERENCE
IF the engine starts & runs ya got a good part.
Bad alternator does the magic of going thru modules! Electrical spikes
I'd say
spray carb cleaner on the base, MAKE SURE the Distrbitor BASE VENT HOLES ARE UNPLUG UNCLOGGED,
go get Permatex Dielectric grease and use that instead of what comes with the module.
When ya play with the clips & such BE PREPARED FOR CRACKING CLIP ENDS
Heat does in the plastic and makes it crack easy.
Here's how I mounted my coil, so much quicker & easier.
Attached Thumbnails Holley Ignition Module Install??-coil-20up-20-26
Old Mar 22, 2003 | 11:42 PM
devianb's Avatar
This is all the ignition stuff I have:
Accel 300+
Accel cap + rotor
Accel ignition module
Accel coil
MSD 8.5mm wires
Bosch platnum +4 plugs
By themselves, I didn't notice any gain, but when combined together I sure did noticed a big difference in mpg and my rpms increased throughout the powerband.
Old Mar 23, 2003 | 12:27 AM
Engine: 3.1
so in seeing your pic KED85, where did ya put the red, yellow and black wires too??
Old Mar 23, 2003 | 07:44 AM
KED85's Avatar
The wiring harness stayed exactly where it was.
ALL wiring went there. No tricks on that detail.
I merely mounted the coil in this position.
That bracket we have that holds coil over exhaust manifolds? I "removed the coil from that spot" placed it under "rain gutter" over hang.
I used thick strips of alumnium as you see. The stainless steel wire?
Holds the coil plug wire away from the coil to prevent chaffing of wire cover.
This is a very simple idea, try not to complicate it. I always use what the factory engineers designed, when possible.
My 1985 Blazer has the same idea and I've done that set up (also Accel coil) for over 100,000 miles of no problems. My Blazer has 211,500 on it.
Old Mar 24, 2003 | 01:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Karl, is that an oil filled coil? Just wondering if it was meant to be installed upside down!
The GM Service Manual http://www.helminc.com and the 82-92 Haynes $16 manual tell you how to replace the module. It's not often that aftermarket performance parts come with installation directions.
Old Mar 24, 2003 | 05:59 PM
KED85's Avatar
Tom
YOU GET MARRIED & JUST BACK FROM HONEYMOON?
Serious, on the coil detail.
I have no idea is oil filled.
I can say that my Accel coil in my Blazer (that's been there for over 100,000 miles) is in the same position, "wrong", not right side up.
No performance problems ever.
None zero zip.
I've even seen other GM coils in this position.
Serious, not a problem by mounting this Accel coil the way I show.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
