Cold Air Intake
Old Mar 26, 2003 | 11:46 AM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Cold Air Intake
I am getting an 85 SC V6 tomorrow, and the air cleaner assembly is missing. all it is is the hole for the intake. There is a lot of space between the engine and the fan, perfect place to put an intake pipe possibly sticking down or something to get good air. Does anyone know if I can just run to auto zone and get one for a honda or something that is the metal pipe with the cone filter on the end. Also, what is that wire plugged into the side of the metal pipe on the intake? its a sensor I think, but what kind and how can I find it to hook up? I have heard that this website or some other one sells cheap intake specifically for these, anyone know where and how much?
Thanks in advance
Old Mar 26, 2003 | 12:05 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Not trying to be a jurk. Use the search button, this has been done over time n time again.
You can install a autozone eruo hot air intake if you choose. I made my own, then when to the v8 tpi intake.
Old Mar 26, 2003 | 12:25 PM
89' RS/blue's Avatar
Car: 1989 RS Camaro
Dale where did u get the V8 TPI intake for ur 2.8? just curious
Old Mar 26, 2003 | 12:31 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
TPI camaros and early MPFI 2.8 Camaros used the same intake
Old Mar 26, 2003 | 12:46 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
That sensor is the MAF. Should be a big tube piece with a wiring harness/clip coming out of it. MAF's are a royal PITA to work with.
Old Mar 26, 2003 | 01:31 PM
Dale's Avatar
Engine: 350 S-TPI
From Brandon Barnett at bb68022002@yahoo.com.
He parts out all years of camaros and is located about 30-40 min away from me. He does ship also.
Old Mar 26, 2003 | 11:04 PM
Car: 95 Z28
What is concidered early?
Is an 85 early?
Old Mar 26, 2003 | 11:12 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I've seen some good ideas here for cold air intakes
Old Mar 27, 2003 | 11:25 AM
KED85's Avatar
Here's what ya need
Mine is for sale for $75 + S & H
Complete, intact, original, restored, NOT BUTCHERED.
No those are NOT K & N filters but excellent condition filters.
Old Mar 27, 2003 | 02:54 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
so there is no difference between the V8 tpi intake and the one i have right??
<img src="http://images.cardomain.com/installs/192000-192999/192436_84_full.jpg">
Old Mar 27, 2003 | 03:35 PM
MDv6man's Avatar
Car: 1983, 1986
You are correct
Old Mar 27, 2003 | 09:17 PM
Nixon1's Avatar
Except yours looks cooler.
Project...we need to get more people to contribute to that! It REALLY needs to be a sticky! People are SO interested in intakes and it's such a common subject that a sticky would make total sense.
Old Mar 28, 2003 | 11:39 AM
ND4SPED's Avatar
so is it safe to s ay that the tpi intake is superior to all?
trev
Old Mar 28, 2003 | 12:58 PM
Dale's Avatar
Engine: 350 S-TPI
I like it becasue it seems to be the only TRUE cold air intake. Its GM parts, and looks stock. I notced from my home rig CAI to this, the exhaust tone was tad deeper. No performance change. Seems to get same mpg.
BTW, my car didnt have any intake system on it when I bought it. It was missing.
Old Mar 28, 2003 | 08:55 PM
Nixon1's Avatar
The TPI-style intake isn't the BEST there is..there can always be better...but I'd say it's the best stock equipment setup. Don't know how it'd fair to, say, a PVC conical setup, but probably pretty damn close. If only the same companies that made performance, custom-bent intakes for slow Hondas could make them for slow domestics as well... Sigh. Guess we'll have to wait for the day we can say we have an AEM CAI kit.
Old Mar 29, 2003 | 03:41 PM
ND4SPED's Avatar
i suppose if you had the ***** yo ucould just cut a hole in the front of your 3rd gen where the tpi filters are. when i look at my car i just cant help but think how those tthings breathe, theres a huge metal plate in front of them, now that i think about it, i bet yo ucould make a pretty good looking ram air setup with the right tools and a really good fabrication shop...what do you think?
trev
Old Mar 29, 2003 | 11:20 PM
Nixon1's Avatar
Problem is how high the radiator rises, and how the thing is arranged. It'd be AWESOME looking to have two huge air ducts on the nose, like on a Camaro, right by the badge, in that angled area..one on either side.. But the radiator is in the way. The way the car is..there's no real way to cut any part of the body for better intake..there's no room to route anything without removing vitals like radiator, headlights, battery, etc.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
