ignition coil install???
Old Apr 19, 2003 | 04:07 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Im outting a holley ignition control module in my car so it will work awsome with my MSD 6al and MSD coil. I want to install a new Pick up coil how hard are they to install??? my car is getting a major tuneup so i want to at least do the module since i know its bad but since im in there i wana do the pick up coil how do you remove and install the pickup coil thanks
if this dosent make sence i just took some stuff to help me sleep.
thanks
Old Apr 19, 2003 | 09:59 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I cant tell you how to do it...but I can tell you that you have to remove the distributor to do it. If you're going to do that to put in a pickup coil, you might as well do a full distributor rebuild. There are several people on the board that can give you much better info on this than me though.
Old Apr 19, 2003 | 04:39 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Nixon is right, you will have to pull distrib to change pickup coil. And do that, might as well do a rebuild on it. I recently did one on mine, it needed it. Not hard to do with basic handtools.
Old Apr 19, 2003 | 06:39 PM
FAST RS's Avatar
I will just hold off on it then. I dont have time to rebuild my dist i gotta finish my 455 and get that running.
Old Apr 19, 2003 | 09:47 PM
KED85's Avatar
Since I know the subject
LEAVE IT ALONE!
Who knows how fragile the heated over time wires may be or how brittle is the plastic.
It the car ignites, ejnoy the privlidge.
Yea, ya remove the entire distributor to change that pick up coil.
Sucks don't it?
The plus is rebuild the whole distributor for slipping onto a 3.4 powered mill!
Old Apr 19, 2003 | 11:18 PM
Nixon1's Avatar
You know Karl, you ***** your 3.4 swap boogie almost as much as Tom ****** his famous tuneup.
Old Apr 19, 2003 | 11:28 PM
devianb's Avatar
Yes, but it is a useful and benefitial ***** post since people like me don't feel like searching for it or bookmarking it.
Old Apr 19, 2003 | 11:33 PM
Nixon1's Avatar
Hehe....
Old Apr 20, 2003 | 06:32 AM
KED85's Avatar
NOW
Would someone be kind and explain the meaning of the usage of *****, here.
Hell, I've seen more "ho's" on Susnset & Hollywood Blvd.
Julia Roberts was a "Ho" in "Pretty Woman"
How did I rise to "ho" status?
I heard about "pimping" & it's really hard for me to understand how its good to be a "pimp".
From" A Little Lost"
Besides, if ya gotta pull a engine, might as well install a decent worthwhile replacment.
Old Apr 20, 2003 | 03:16 PM
FAST RS's Avatar
Exactly thats why when my 350 died in my firebird i put a 455 in your there do it right the first time and dont have to worry about going back. besides whos gonna complain about more power. Theres no replacement for displacement.
Old Apr 20, 2003 | 03:29 PM
Dale's Avatar
Engine: 350 S-TPI
Some say the replacement for displacement is technology. And no, thats not from import guys either, thats from some 4th gen people at another camaro site.
Old Apr 20, 2003 | 07:22 PM
Nixon1's Avatar
Dale has a point there....you seen some of the 4 bangers pushing over 200-300 horses? That's on 4 stinky little cylinders... And those bastards get like 30 mpg too. Sad to say it, but low displacement and high technology is the future. 4 cylinders are here to stay....
Old Apr 20, 2003 | 07:33 PM
Dale's Avatar
Engine: 350 S-TPI
I wasn't and dont plan to start a flame war, please nobody take prev post the wrong way.
I do agree that if you do the same mods to a larger displacment engine, of course you will get better results with more power.
But Nixon is right, way the future appears right now will be smaller engines with better technology, and better mpg.
3.4l ohc engine=160hp.
3.4l dohc, 24 valve=210+hp
Gotta be the technology.
Old Apr 20, 2003 | 08:08 PM
FAST RS's Avatar
I agree my moms new altima with a 3.5 is pushing 260 HP outta a V6 that car can spank my camaro i took it to 120 then it hit the gov and it still had a ways to go. I would like to buy civic for gas milage my frineds civiv was a 99 we drove 500 miles to arizona and still had a 1/4 of a tank of gas in the damn thing.
Fast355
Dec 2, 2016 06:33 PM
TheExaminer
Aug 25, 2015 07:34 PM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
