not starting
Old Apr 22, 2003 | 07:52 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
not starting
ok,cars has been missing a lil bit here n their the aspt couple days,today started up,got about 5 ft n it died, i dont think im getting spark,i ahvent checked,gotta new control mod. for the ignition last month,and a new coil alreday,got a code 22 and 23, but ive had the 22 for a while,any ideas?!?!??
Old Apr 23, 2003 | 12:45 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Well those are both throttle position sensor codes. Code 22 is low voltage..meaning, your throttle position sensor is acting up...giving an output too low. Code 23, as I interpret it, means the sensor finally died. Now, I'm not sure whether the throttle position sensor will cause a car not to operate...I assume it'll drive a little ways but run like *** because the car has to throw a default value to something that is continuously variable.
I think a failing TPS would cause severe drive-ability issues because the car wouldn't know how much you were on the throttle, and I don't know how much other sensors, like the MAF, can compensate for that. Probably not much and not very accurately.
Replace your throttle position sensor to begin with and see what happens. Also as you mentioned, check for spark. Did you remember to put the dielectric grease on the underside of the ICM? I believe ICMs are prone to failure unless installed properly and installed with that grease, because the intense heat in there burn the suckers up. Also voltage spikes will trash an ICM as well. Karl (KED85) on the boards had a problem with his new alternator short-circuiting his ICM. He went through several before he found out.
If you arent getting spark, I'd bet on the ICM.....coils don't typically fail. Many on the boards are still using the original, 10+ year old coils...
Old Apr 23, 2003 | 02:10 PM
Transmission: t-5
it started right up a half hour later, it always does this,but i thought it finally kicked it, the 23 is the manifold air temp. sensor. the tps is jsut mis adjusted because it ook it off a few months back and havent adjusted it yet. i put all the grease on when i got it. im nots rue what the hell it is.
Old Apr 23, 2003 | 11:06 PM
Nixon1's Avatar
I was unaware that 2.8's had MAT sensors... Are they located near the MAF? Either way, the MAT is not a major sensor and shouldn't cause problems. Just lets the car know what temperature the incoming air is so it can fine-tune the air fuel ratios to account for air density due to temperature differences.
By the way...adjust the TPS! It will probably help a LOT with the driveability issues!
Old Apr 23, 2003 | 11:26 PM
Transmission: t-5
i'll do that. im going nuts w/ the nto starting thing,it only does it once and a while,and when it doeas it,if i wait 10minutes it starts fine afterwords.
Old Apr 25, 2003 | 09:04 PM
Akshay's Avatar
Sounds like faulty ign. coil.
Akshay
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
